Help finding a part!!!
Jamierara
Maple Valley, WA
2000 VW Beetle TDI (custom built) & 1982 VW Vanagon non turbo diesel & 2005 Jetta (MK4)
I replaced the turbo on my (early) 2005 Jetta TDI, dummy me when I broke the oil line didn't write down the part number:eek:
I cant find the correct part.
It was a copper coloured hard-line that had to be threaded into the turbo and into the oil pump... all I can find is a hard line with the wrong tip for the turbo or a flexible line that would fit both sides, Advice?
PrintSmith
Bailey, CO
2003 Jetta TDI - RIP June 2016 - 470,000 on clock. 2004 Jetta TDI Sport new to me June 2016
Don't have a part number for you, but you're looking for the oil feed line and it's available through not only the vendors on this site, but also from any parts store, including online stores like Jegs and Rock Auto. The Jegs website will likely have the OEM part number in the description if you really want to order it through the dealer.
JETaah
Vendor , w/Business number
mi 48836
96 B4V, 1999.5 jettaIV,2005 BEW Beetle
If it is copper colored it is not likely that it is the original. Original line would have been black paint coated and the aftermarket ones that I've seen are shiny metal.
My vote is to replace it with a braided version, too.
If you do opt for the hard line and live in a corrosive environment you would do well to put a dab of antiseize compound on the tube where the compression nut slides over it. Put some (just a little),compound on the fitting's threads, too being careful not to introduce the compound into the oil line.
This should prevent the tube from getting twisted off if you need to remove it years from now.
Jamierara
Maple Valley, WA
The end that goes onto the turbo is still missing the screw:( is it a separate part?
Jamierara
Maple Valley, WA
that is my guess is on what I'm missing, I just need to know what exact size and material.
JETaah
mi 48836
You will need a copper crush sealing washer between that fitting and the turbo...and of course, two more crush washers for the banjo fitting.
Not sure if they would be the same size as the turbo end.
JETaah
mi 48836
You might consult Franko6 for this. he probably has what fittings you need from the oil filter bracket to the turbo.
Jamierara
Maple Valley, WA
I message him and I have not gotten a response. anything I can do?
eddieleephd
Battle Ground, Wa
2002 jetta Wagon
Take the old line to the hydraulic shop and have them make your new flexible line. You can use a tape measure to ensure the length you want.
All hydraulic shops should have the necessary adapters and such
Sent from my Armor_2 using Tapatalk
eddieleephd
Battle Ground, Wa
2002 jetta Wagon
Cross parts list for turbo feed line.
Parts:
JM0410******* - 10mm adapter to turbo********** $4.70
JM0412******* - 12mm adapter to oil housing* $7.68
10691n-4-4* - straight connector for hose*** $10.41
90* "your choice"
4 C6X-S****** - swivel elbow*************************** $4.76
13991n-4-4 -90*hose fitting************************* $11.02
My hose assembly $36.05
My bill shows the 10mm adapter, 12mm adapter, swivel elbow, and hose assembly.
Total $57.06*** including adapters, and swivel elbow.
I prefer the swivel elbow on the turbo side.
Made it much easier to install and replace
Jamierara
Maple Valley, WA
Ended up going to the dealership for the part, it was $92 for the little converter bolt
