juanitoglez
So for the past few months my ac has been acting up. Its would take a good 5-10 minutes before the ac would actually start blowing cold air. Looked this problem up and it seemed to be common. Fast forward a couple months and my ac was no longer cooling at all. Thought the problem was just my ac fan. Took it in to VW for a diagnosis. According to the diagnosis both fans were bad, plus my ac high pressure switch was also bad. So I purchased new fans and a new ac pressure switch and installed them. Well......
Both fans still wont turn on, and my ac is still not blowing cold. I checked the fan fuse under the hood by the battery and the one in the inside panel. Both fuses seem to be good. Has anyone had this issue? I would think this has to do with a certain fuse or wire.
