larsbar
help: starts then dies
I have a 2001 golf with a vnt 17, pp764's 11mm pump, and rc2. It ran fine last night, but this morning (+7 C) it will not start. Last night it seemed a little less powerful, and a little rougher, but very little and could easily have been due to the damp weather and higher altitude here(I brought the car to edmonton from virginia last week). When I go to start it, it fires right up, immediately, first or second crank, just as it always has, and then dies immediately. No funny noises, no grinding or squealing. If I quickly blip the throttle it will give a 1 second roar before it dies as well as a cloud of white smoke. The check engine light is on, and has been for a while. It stays on because I have no EGR, I would like to turn that off but don't know how. I got it checked last week and my glow plug harness needs to be replaced, but if that were the case it would not fire initially. My glow plug light comes on behind the tach for a 1/4 second right when I put the key in but does not stay on any longer than the other start-up lights. As long as the key is in but the car is not started there is a little flashing pic of a car with a key on it. That may be normal, I don't know. I have no anti shudder valve as far as I can see. I have a different intake opening towards the drivers side for the intercooler pipe. I do not have vag-com. Any help appreciated.
