PARKERS250R
Belt broke on 2004 tdi beetle, rebuilt head, put everything back together, turns over, have fuel, wont start, any suggestions PLEASE!!
this^^.... i bought an 05' golf from the parking lot of a local independent garage who's radio ad stated "specializing in all european makes and models, including TDI" ... they diagnosed the car with a bad tandem pump after the owner replaced the alternator and accidentally swapped lines, got the car home and spotted the issue within two minutesIf you are in time, no codes (something disconnected), check to make sure your fuel lines are not reversed. They are both the same size, easily reversed.
See post #13. He said that it is the 2000 not the 2004.This is a PD car. Has tandem pump
