Ronstarman
Hey all
Am having a shifting problem and am hoping it is only a simple adjustment. I have 300k on car and I don't think trans was adjusted at all.
Lately it has been hard to shift and when I push clutch in it at times it grinds a bit
Some times it hangs up in 5th gear to where I need to turn off and then I can shift.How long does the cable last on a manual trans and is it maybe just needs to be adjusted or quite possible needs cable replaced.
Am using a company car for now since I don't want to get stranded at the wrong time and I still need to fix the thermostat housing since when they changed it dang thing still leaks.
Is the cable easy to replace if that is what it is,or do I need to have a garage do it? All help from anyone helps me out. I am also contemplating buying another car and work on this at my leisure,when I can find a place that I can do it at
Ron 99 VW Jetta TDI 1.9 5 speed
