TexasDieselInjected
I have a 2006 TDI with the auto-temp or climate control module each front seat passenger can control their own temperature. Towards the end of summer, the car would either blow air, or it wouldn't, almost as if it had a loose wire, or hit a speed bump. It wasn't as important then, perfect weather outside, but now its just cold! We need heat & defrosting blower to keep the windshield clear.
I have checked the fuse box, all good 30amp fuse that feeds the blower fan. I've also chased down the power lead that plugs into the blower fan / module itself, it also has power.
Now what ? Is it the dash controls, or the module that is attached to the side of the fan motor on the passenger side floorboard ?
Please advise, I really can't afford a dealer fix, especially if this is a common, or easy repair I'd rather do it myself at home.
Thank you for your time,
John
John
