I wasn't planning to remove the connecting pipe (as the nuts holding it to the turbo look also welded in place and I'm afraid the studs from the turbo will break off)... if I cut off the bolt heads, will I be able to pull the cooler away from the connecting pipe once I remove the 3 screws holding the cooler to the intake manifold? I suppose I can destroy the cooler, as I've got a spare sitting around... should only take me a couple of weeks to find it...
Y.
