B batkotivalio New member Joined Dec 9, 2009 Location Bulgaria TDI VW-Golf Jul 8, 2020 #1 Hi I tried to connect to controller, but no response from controller. Other doors and windows are working fine. Golf is 2000y. 1,9TDI 115hp.
W wonneber Top Post Dawg Joined Oct 12, 2011 Location Monroe, NY, USA TDI 2014 Jetta Sportwagon,2003 Jetta 261K Sold but not forgotten Jul 8, 2020 #2 Did you scan for codes?
B batkotivalio New member Joined Dec 9, 2009 Location Bulgaria TDI VW-Golf Jul 9, 2020 #3 I can't connect to comfort module!
W wonneber Top Post Dawg Joined Oct 12, 2011 Location Monroe, NY, USA TDI 2014 Jetta Sportwagon,2003 Jetta 261K Sold but not forgotten Jul 9, 2020 #4 Do other controllers reply? Trying to determine if it's a wire going through the door jam broken or shorted. There's been people with both problems. There's a controller inside each door. I think they all should reply.
B batkotivalio New member Joined Dec 9, 2009 Location Bulgaria TDI VW-Golf Jul 10, 2020 #5 I'll try to measure for broken cable. Are you sure that there are controllers in each door?
benmarks Veteran Member Joined Jun 14, 2003 Location Portland, OR TDI 2004 Jetta GLS Sedan Platinum Gray Jul 10, 2020 #6 Yes, there are door modules in each door and you should be able to communicate with both of them with VCDS.
