BuckeyeMan71
Lately I’ve been noticing that my Jetta wagen has been taking longer to build boost. Where should I start looking
Exactly how do you know this?
So your actual complaint (the first 'C') is low/inconsistent power? You jumped to the cause (the second 'C') without addressing the first.
Complaint
Cause
Correction
The ECU controls, and thus monitors, boost. Which can be viewed (actual vs. requested) in the scan data. If it gets too far off... typically even before there is any complaint... the ECU will flag a DTC and turn the MIL on. Do you have that?
Now that we have your first C, we can go after the second. Common things that could cause low power besides boost are the MAF, and the injectors, and even the intake/EGR.
Is it limp mode? I find that during limp mode, pressing the throttle halfway will feel like it gives more power than during wot.When I push down on the pedal the car goes but sometimes I have to let off pedal and I’m not flooring it to get the boost to kick in
If your left hand fits behind the engine, you could reach back there and press the actuator arm down and feel whether it's moving smoothly. That's the first place I'd look.
No not in limp mode just loss of boost
