Dadwagon
Morning!
2004 TDI PD BEW W/auto trans
CEL came on a few days ago, ran VAG and pulled these two engine TCs.
MAF implausible intermittent and coolant temp sensor signal too high intermittent
So I Checked for vacuum leaks with carb spray (no luck finding leaks) Replaced the air box filter, and threw in new coolant temp sensor, and cleared the fault codes
MAF code is gone, but I’m still getting the CTS fault.
The car seems to run fine, only noticeable thing I detect is a higher than normal RPM upon start up
Cam sounds ok ( at least I think?)
Any ideas suggestions on what’s going on
