8v-of-fury
So I just got this car, and am in the midst of getting everything properly operational. The AC is the ticket now with rising ambient temperatures.
I replaced the FCM straight off the bat because I heard how they are often the culprit. Everything appears to be fine except for two things; my compressor coil reads open on a ohms test.. and it doesn't receive its 9-9.5v signal.
I found a chart of the T14's pin out (not a picture mind you of the pin layout) and what each does, but i don't think its correct for my car anyway. I have battery voltage on a pin the chart says is unused for one thing, and battery voltage on other pins that i think should be other pins according to the chart.
I found what appears to be t10 as having continuity to the compressor from the T14 plug, so thats in order. I also found a myriad of battery voltage pins, but they didn't necessarily line up the charts pin out.
With the KEY ON and AC ON, we have the AC light on and both fans running on LOW speed. There is no output to the compressor.
---EDIT--- upon writing this and doing more research I found a pinout picture!
T13 shows on the chart as engine overheat signal from ECT, in my connector this pin fluctuates between 10v, drops a little to like 7v and then drops to 5v and back up to 10v in a completely steady rhythm of voltage fluctuation. Is this what a duty cycle sensor looks like to an analog voltmeter??
I am pretty sure I read that if the fans are coming on, then the OUTPUT for making the AC run is correct??
