Battery Light Flickering
mjgorz98
New Jersey
1997 Passat TDI
I started my 97 passat this morning and everything was normal. About 5 minutes of driving later my battery light starting flickering. When i was at red lights, the light was bright and clearing flickering. When i was driving or accelerating, the light, while still one, was extremely dim and hardly visible. What could this problem be? It still starts fine
Andreas1989
Norway
Golf MK3 1995 1Z
Just been there my self and ended up replacing the voltage regulator on the alternator{the part with the brushes), it instantly fixed the problems you are describing here :)
Sent fra min GT-I9300 via Tapatalk
RabbitGTI
Wisconsin
B4 Passat Sedan
When replacing the volt reg assembly, take a look at the slip rings. If the slip rings have deep grooves in them, take the alternator to a good automotive electronics shop for a rebuild. Probably only a little over $100 for that. Whatever you do, do not abandon an OEM Bosch alternator for a rebuild from a chain store.
