LokiWolf
Nope. Welcome to the discussion. I suggest you read this thread, it will catch you up.Since current NavTeq map and POI files are available from multiple sources, is there a way, other than the VW/NavTeq disc to load them onto our RNS-510's?
With my Pioner AVIC unit, I can boot it into Windows CE "test mode", and simply copy files over from an SD card.
The RNS-510 seems like a WinCE-based unit. If it is, there should be a way to boot directly into CE, and copy the files into the proper folders.
Depending on what Navi system is actually running on the unit (Pioneer uses iGo), it might also need some other file modification. But, it could be doable, and a way to keep current.
I guess the two big questions for the RNS-510 are:
-What is its OS?
-What Navi program is running on that OS?
The RNS-510 uses VxWorks for its OS, with a Java Frontend.
There is no Nav "Program".
The data is provided by Navteq.
The ONLY way to update the Nav database is via DVD.
POI can be added via SD.
Sent from my iPad using Tapatalk HD
