machinebaby
Hi all. I have a 2003 TDI wagon, manual, with a few mods. I can’t remember exactly the mods I have reached out to the PO for the mods list but not sure. If he has time to get back to me I’ll post what he send here. Pretty sure I have larger turbo, bigger injectors.
I am a bit worried. I had an old Groupon and had a shop change my oil about 5k mi ago. Didn’t think to change it, as they had oil in 505.00 spec and seemed to know what the car needed. Like an idiot I didn’t check the level when I left, or for the last month and a half since the change.
Recently my car has started to lose pep over about 2k rpm. Searches made it sound like it is either in limp or the MAF is failing. Decided to do an oil change today and noticed that the dipstick was reading at least an inch over the bend.
So, i feel like an idiot and it won’t happen again. My question is, what should I look for in terms of damage that might be done or continuing to happen? There isn’t much tailpipe smoke and none of it is blue. In fact there is a good deal less smoke than there was before the power started waning.
Thoughts?
Thank you.
Thoughts?
Thank you.
