Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Past TDIFests > TDIFest 2010
TDIFest 2010 Discussion about TDIFest 2010 on the Labour Day weekend (September 3-5th, 2010) .
Old May 7th, 2010, 18:53   #31
Torque_Delight
Modded
Torque_Delight's Avatar
Fuel Economy: ~5 l/100km
Removing the crappy chiptuning you have and installing an evrymod with a MAP offset mod to get the real stable, reliable and smokeless power you always wanted !
Jetta TDI 2001 GL (~680 000 km) : GT-1749VB, EGT/O2/Boost Gauges, Scangauge II, Sachs VR6 Clutch kit, OEM G60 Flywheel, 502 Nozzles, MRTuning, Euroswitch, Hella Micro-DE w/ yellow bulb, Rear fog, Wolfsburg's Heated Seats, Koni STR.T Shocks, H&R OE Sport Springs, TT Control Arm Bushings, 17" Santa Monica (GTI VR6) Wheels, DieselGeek Skid Plate, FX35 HID Projectors Retrofit, GLI Tail Lights, 2004 Trunk lid.
Torque_Delight is offline   Reply With Quote
Old May 8th, 2010, 10:41   #32
FlashT
Post
How about using some nice and clean (not to mention high quality) MOPAR ATF +3 to top off the power steering fluid?
It's the same color, so what's the worst that could happen?
Thinking of lowering? Read This first.
FlashT is offline   Reply With Quote
Old May 8th, 2010, 18:35   #33
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
Originally Posted by Torque_Delight
Removing the crappy chip tuning you have and installing an evry mod with a MAP offset mod to get the real stable, reliable and smokeless power you always wanted !
Been there. Done that. See my sig.
I mean... Hey, it works (in an A3...).
Svante Arrhenius 1896
Page generated in 0.12495 seconds with 10 queries
[Output: 56.92 Kb. compressed to 51.43 Kb. by saving 5.49 Kb. (9.64%)]
