Old January 26th, 2012, 21:13   #1
E-Z Wood
E-Z Wood's Avatar
Default Smyth rwd conversion
I remember reading somewhere about a myth performance making a rwd kit to put the engine where the back seat is via a rear subframe. Anyone do this, or thinking about doing this?
13 scion Fr-s 6mt
E-Z Wood is offline   Reply With Quote
Old January 27th, 2012, 07:36   #2
Deebeaux
Deebeaux's Avatar
Fuel Economy: 51,47,40
You're probably referring to the Smyth Performance G3F. It's not so much a "rwd kit" as it is a "kit car." You build a G3F using a Jetta donor car in the same fashion you build a Factory Five Cobra/GTM using a Mustang/Corvette donor car.
I wish I had a better link than a Facebook page for them, but here's the details: https://www.facebook.com/SmythPerformance
--- Dave | TDIClub Vendor | ERF 6-Speed, Malone Stage 2
Deebeaux is offline   Reply With Quote
Old January 27th, 2012, 13:21   #3
IXLR8
Here is the full forum post about the G3F project.
http://www.ffcars.com/forums/139-smy...ark-smith.html
Bottom line, the Alpha car has been driven and is now apart getting production parts installed. There are 2 Beta cars being built by costumers that are waiting for parts to continue.
Readers Digest version: You start with a MKIV Jetta or Golf 4dr, cut it up, attach some frames, move engine to rear, attach body.. go drive.
Jim Peck
'14 TDI JSW 6M, Blue, 39,980 miles
'12 TDI Passat SE 6M, Platinum Gray w/Moonrock- 86,750 miles, 52 mpg. Buyback 12/16/16
'02 TDI Golf, 5 spd., 298K miles -PP520, RC3+ , VNT-17, Webasto, .68 5th gear. Failed safety inspect for rust
IXLR8 is offline   Reply With Quote
Old January 28th, 2012, 09:12   #4
OlyTDI
TDI(s): '04 Golf
Yeah...but why?
2004 Golf GL PD TDI
Malone Tuned, SBC Stage II Daily, Nicktane Cat 2 fuel filter, Dieselgeek bypass oil filter, Whitedog intake hose fix, A4 Defender skid plate, GLI Recaros, Check Temp III, Ventectomy, LED trunk lighting mod, Volx glass headlight lenses, VR6 front and wagon rear springs. Koni FSDs all around. FrostHeater with bumper mounted plug-in mod (details here).
OlyTDI is offline   Reply With Quote
Old January 28th, 2012, 09:16   #5
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Originally Posted by OlyTDI View Post
Yeah...but why?
Because you can!
-George Bernard Shaw
Old January 28th, 2012, 10:15   #6
IXLR8
Yeah...but why?
It will be lighter, quicker, better handling, more fun to drive, better fuel economy than the original Jetta/Golf. The thought is to take a car that is at the end of it's life, maybe has a bit of rust or has been banged up a bit and "recycle" it to something newer/better.
Jim Peck
Old March 16th, 2012, 18:28   #7
E-Z Wood
E-Z Wood's Avatar
I am not referring to the g3f. I think I read about using a new subframe in the rear and keep the original size and shape but moving the motor and transaxle to about where the vertical part of the rear seat is, making a mid engine rwd golf or jetta.
13 scion Fr-s 6mt
Old March 17th, 2012, 05:27   #8
Satiro
Satiro's Avatar
AWESOME CAR that G3F! very impressive.
I like the idea of 'just' swapping the engine to rear in the original body
Handling improvements must be HUGE for sure. I'm so envious!
Rub87remap ARLpistons PD100rods Sputters ARLbolts Rosten'sMainStuds VitonSeals PortedHead Rosten'sValveSpring ASVpump 11mmHead DE143 11mmSprings GT18v Race520 BigFMIC fuelCooler LiftPump CRfuelFilter PD130Manifold Dbilas260cam BlackLifters OilCooler 312mm+porscheCalipers Sigma5SSK BilsteinEibach MK4RearBearings/Calipers EibachProKitSwayBars
Satiro is offline   Reply With Quote
Old March 17th, 2012, 05:50   #9
IXLR8
The only Smyth car available is the G3F, it does have a new sub-frame to put the engine in the rear. Smyth is also considering making a MKIV truck, but the engine stays in the front on that. Those are the only two vehicles that Smyth is making, or considering making, at the present time.
Jim Peck
Old March 18th, 2012, 14:35   #10
Satiro
Satiro's Avatar
Take a look of this project
http://forums.vwvortex.com/showthrea...Race-car-build
with a TDI engine, that engine relocation should be GREAT.
Smyth Performance BgRedBrck TDI Power Enhancements 1 April 7th, 2010 05:40
Is this possible? RWD on Golf 4 TDI? zGb TDI Power Enhancements 28 July 6th, 2006 14:40
RWD gearbox for TDi conversion TDiHotRod TDI Conversions 9 January 25th, 2006 03:55
RWD TDI? thespian666 TDI 101 13 March 24th, 2005 20:18
FWD or RWD WillR VW B5 Passat TDIs 7 January 4th, 2005 10:20
Page generated in 0.16547 seconds with 11 queries
[Output: 101.91 Kb. compressed to 86.71 Kb. by saving 15.20 Kb. (14.91%)]
