Old December 6th, 2008, 09:38   #31
RC
RC's Avatar
Loking for a B5 for a friend. What years are the B5's available without the newer high pressure PD injection systems, if any?
Two 96 TDI Passat Wagons, Bypass Filters, Chipped
87 MB 300TD, 97 Ram2500, Kubota Tractor
24 cylinders sipping the sweet sauce of the soy bean
RC is offline   Reply With Quote
Old December 8th, 2008, 08:41   #32
TDForNow
TDForNow's Avatar
Fuel Economy: (Passat) 41 mpg, avg, (Quantum) 45mpg. avg
You might want to consider selling him one of yours. Non-PD Passats were only available in NA from '95 to '97 and becoming extremely hard to find. Good luck!
Alain
ABS, ASR, ASC, BSD, BSW, DMS, EBAS, ESC, ESP, EDL, ISA, LDW, TPS, TPW to bale their arses out ... and ONSTAR* and E-CALL to rescue them for "successfully" defeating any or all of these!!
REALLY!! .... Drivers Wanted!!
It's no wonder the OTHER animals haven't "evolved" away from survival of the fittest! ... Looking at our "progress", they know they're better off!!"
'99 Passat AEB GLS Wagon
'95 Passat GLX Wagon
'85 Quantum TD (RIP)
TDForNow is offline   Reply With Quote
Old December 8th, 2008, 10:53   #33
sharplikestump
Some general Question on Passats:
I currently own a 2004 TDI Jetta wagon 5 spd. and love it. However, I drove a 2004 Passat the other day...1.8T gasser, Tiptronic, AWD.(which would be great for here in the mtns of CO. We both loved the car, and would concider adding one to the stable. (NOT parting with the TDI Jetta).
Being clueless on them, I humbly come to the source of knowlege: How do these cars compare for reliability, economy, etc.? Should I even concider the 1.8T or 3.0 6 cyl. gassers? Are some equipped with transverse mounted engines, while others are not? What are the good years? (The 1.8T that I drove was a 2005). PM me if you prefer.
Thanks to all who take the time to share their knowlege.
Mike
sharplikestump is offline   Reply With Quote
Old February 3rd, 2009, 12:07   #34
dukku
dukku's Avatar
The 1.8 T engine is great .It is also a very "tunable" one. The fuel consumption is about 10 liters/100 km (you make the conversion) and the torque is great. I would chose a 1.8 T.What year?...any year, just check trhe gearbox if you prefer a tiptronic. The oil must be changed every 200 000 km.(In Europe the use multitronic gearboxes too and this one requires an oil change every 60 000 km).
2011 Audi A4 Allroad 3.0TDI mTm
dukku is offline   Reply With Quote
Old July 26th, 2010, 11:33   #35
vicius_the_one
vicius_the_one's Avatar
TDI(s): Passat 3b6
Guys, I want to remove my cluster so I attach some LED onto it butI don't know how to open cluster's case and remove needles. And mostly i wanna see how to reset needles back
vicius_the_one is offline   Reply With Quote
Old July 26th, 2010, 11:34   #36
vicius_the_one
TDI(s): Passat 3b6
Old August 18th, 2010, 09:39   #37
abctdi
abctdi's Avatar
How about a FAQ concerning timing belt inpection and replacement?
I heard there is an 80k mile replacement requirement vs. the 100k in my manual, but I've not received anything from VW and I'm the original owner. I'll be at 80k this year.
05 Passat GLS 2.0 PD, UnChained & Steel GPs by VW, 15" steelies, New TB/WP, motor mounts, alt pulley, trans filter, cv boots, TSB #P9/66C8, clear bra & tint, both raxles. Now only driven 1-2 times per week. 123k miles (sold)
DD is a 2012 Kia Optima SX turbo with 274 hp and 269lb-ft@1,750-4,500rpm
abctdi is offline   Reply With Quote
Old August 18th, 2010, 10:00   #38
leicaman
leicaman's Avatar
Fuel Economy: Much better than the average car... :o)
You didn't have it done when you went through all the bother of the balance shaft? That is half the labor already. I had mine replaced at 57k. Yeah it was early but it is good to go about 140k. Oilhammer said the 100k interval was really doable as per timing belts he's seen. I would defer to a guru such as Oilhammer for a final word on this. What is most important if you tear it down for a TB, make sure you replace those timing belt path things such as the tensioner, waterpump and stretch bolts. Don't be foolish cheap.
2015 Golf SE TDI with DSG, 88k.
and formerly a 2005 Passat GLS TDI - RIP, 208k miles. Many good memories and friends made with this car.
leicaman is offline   Reply With Quote
Old August 18th, 2010, 12:23   #39
abctdi
abctdi's Avatar
Are you kidding? I was lucky to get VW to just do the BSM on their dime. They were not interested in complicating things in their mind. It would have been nice, but free is the best price.
I will do the whole deal when it's time though, and inspect the cam.
Did anyone here get formally notified by VW of the 80k interval?
Old August 24th, 2010, 07:58   #40
leicaman
leicaman's Avatar
Heck no. I think the 80k interval is a ruse to get them to see and hear the motor on these cars if they make it that long with the chain driven balance shaft. With that said, I will have mine done when the current belt has 85k on it. I'll have it inspected and if it needs it sooner than fine. Oilhammer told me that many 100k belts look fine. I had my timng belt etc. replaced while Oilhammer was doing the BS gear conversion.
Old August 29th, 2010, 11:20   #41
abctdi
abctdi's Avatar
Thanks. I heard that inspection of timing belts usually shows nothing to go on, there are no real tell tale signs until just before failure.
So OH or MG or other gurus, True or False?
Old August 30th, 2010, 01:48   #42
vicius_the_one
TDI(s): Passat 3b6
Passat 01-05 1,9 tdi broked it's toothed belt at 179.000km(it has not been changed at 90.000km)....so you can imagine how strong it is.
Old February 9th, 2011, 19:29   #43
scottie_boy99
i am looking at buying a passat tdi, anywhere from 2003 to 2005, any recommendations as to what year i should get and why? i will be possibly "chipping" it and putting a 2.5" or 3.0" straight pipe exhaust on it... is there any pollution controls on the exhaust? what are these engines rated at stock for hp and torque?..
i am also leaning towards an automatic tranny.... is that a good idea?
thanks for the advice in advance
scott
former 04 jetta owner
scottie_boy99
2004 jetta tdi sport tiptronic. slightly modified intake, 2.5" turbo back straight thru exhaust. ventectomy
scottie_boy99 is offline   Reply With Quote
Old April 17th, 2011, 06:42   #44
JerryKib
Fuel Economy: 46/41/36;45,35,30
scott
In North America, the Passat was offered with the TDI engine in 2004 and 2005 model years (and some previously in the 1990s). The 2004 - 2005 Passat TDIs only came with a 5 speed auto transmission, and were rated at 134 horsepower and 247 pounds of torque. They came with a catalytic converter in the exhaust system, but no special emmissions controls that I know of otherwise. A search will get you a bunch of info about chipping these engines. Maybe about exhaust pipes, too.
Jerry Kibby
01 Golf GL TDI(auto) DG skid plate, ventectomy, PP357, RC2, stainless 2.5" exhaust
2004 Passat GLS wagon TDI, Geared BS Module,
Steel Glow Plugs, Evo skid plate
JerryKib is offline   Reply With Quote
Old September 30th, 2011, 06:44   #45
442JOHN
Question Is a 2004 Passat TDI a good car?
We just bought a 199.5 Jetta TDI amd have found 2004 Passat TDI with only 92000 miles on it for under $4000 and was wondering if this is a good car? Sound too cheap to me?
442JOHN is offline   Reply With Quote
Page generated in 0.18132 seconds with 12 queries
[Output: 126.44 Kb. compressed to 104.78 Kb. by saving 21.66 Kb. (17.13%)]
