GreenLantern_TDI
Trimming of the plastic oil pan cover is required. It is extremely brittle plastic and easy to cut and snap off the piece required for install. Pic shows Fumoto pointed at the 6 O clock position but i decided id move it to point to the 4 O clock position instead. As you can see in the photo it woulda been fine at the 6 O clock position as it has more than 12mm clearance between it and the Ares skid plate. I have seen posts saying this isnt possible so I thought I would post pictures and clear this issue up.
Oil pan.
Fumoto installed.
Clearance above Ares skid plate.
Oil pan.
Fumoto installed.
