craigldavis
- Joined
- May 21, 2003
- TDI
- 2009 JSW M/T; 2014 Q7
I have the diesel geek P2015 repair bracket and it has been installed for over a year.If I were you I'd but the dieselgeek P2015 fix for $68, and a used "clean" EGR filter before you go in.
I pulled the codes and call Jim at dieselgeek, I’m actually getting a P 2004 and a P 2006. Jim recommended I check to be sure the actuator arm is correctly seated on the balls.
Turns out that cured my CEL after I cleared the codes.
I’ve driven 400 miles now, and the EGR low pressure has not returned either.
If all goes well I will show up to my appointment with no Codes Pending or active.
