In the initial planning stages for doing a TDI swap into my R. A trusted guru will be doing the work, I will leave him anonymous unless he decides to chime in.
The car currently has an HPA FT450 turbo setup, pushing about 320 AWTQ and 370 awhp. It also has water / meth, boost controllers, and more gauges than I can possibly read. All the gasser stuff will need to be sold to partially fund the swap.
The good news is that the drivetrain is nicely set up for this. It has diesel gears already, peloquins front and rear, competition haldex controller, big brakes, kw v3 suspension and way too much more to list.
I am trying to decide which engine to run. Originally I looked into a BKD, but it was too much $ for my budget and had an "A" head so I am rethinking.
Current idea is a PD like this:
- BHW or bored out BEW block.
- BHW pistons, crank
- 8v head with port work. Bigger valves? Cam? Upgraded springs?
- rosten rods
- RyanP GTB2260VK kit
- RyanP manifolds, downpipes, and S3 inter cooler
- BHW ecu with tuning
Any thoughts on this? Should I consider CR?
Thanks in advance!
- rosten rods
Thanks in advance!
