SFHGolfTDI
- Joined
- Nov 3, 2003
- Location
- Ventura, CA
- TDI
- 2002 Jolf GLS TDI - Reflex Silver (purchased 2011) | Previously: 2001 Golf GL TDI - Indigo Blue (sold 2005)
Hi all, I searched for similar problems but couldn't find.
I noticed that both side markers were out about 6 months ago (had the car for a year). Went to the auto parts store and replaced with 2 2825 / 194 bulbs. Everything worked fine, and I forgot about it.
After finally getting around to installing my euroswitch and playing around with it, I noticed they were not coming on with the middle parking setting. So I pulled the bulbs, and sure enough, only 5-6 months later, they are burned out again; I don't know how long they have been that way.
I put new ones in and they work, for now. The fuses were fine also. Any clue what would cause this? I did see on another forum string that these should be W3W not the 5 watt 194s commonly recommended because W5W will burn the holder (my holder isn't burnt, just the bulbs). Could this be the issue? Also, in that case, would LEDs be a better option?
