dieselherb1
- Joined
- Oct 25, 2008
- Location
- Va.
- TDI
- 06 MK5,09 Mk5 CR,03 Mk4,96,2-97 B4s,98 A3,2000 A4,4 Caddies( 2-1.6TD,1.6,TDI) Chevys 6.2,6.5,6.5TD
Its been 5 years now has anyone really achieved the most HP from the CR engines?
Heat and EGT is also a problem.Fuelling is the limiting factor right now I think for or Max power.
Yes, I would pretty much guarantee the duramax hpfp flows significantly more than ours. After all, it has to supply a much larger and more powerful motor. I doubt that it is anything close to a plug and play swap though. A plug and play CP3 kit would be awesome.I've read the Duramax pump can be used. Can it fuel more?
