That really depends on what motor. If the motor has a poorly designed intake, then that could be very attainable.03PlatinumTDI said:Install video - http://www.spike.com/video/tdi-performance/2930828
That 10% HP increase that they keep throwing around is really raising my Bull$h!t meter.
They stock/OEM box is great/perfect for a stock car, but as you start adding more fuel and requestion more air, there is certainly a need to open the intake.Farfromovin said:Sorry Bob, but I gotta quote Nick here after reading your post...
Because the owners manual doesn't allow it...Bob_Fout said:Yup, folks seek out the larger Euro OEM airbox parts when they bump the mods. Why can't a non-OEM solution be effective to?
It totally can. I'm glad you guys are keeping this thread alive with updates and info. The one thing I don't quite understand though is how you guys are happy to completely ditch the "cold" and perhaps slightly pressurized draw of the factory setup. While it might not be too significant, you are now simply sucking heated (perhaps) underhood air that could run at a significantly lower pressure when driving at speed. It would seem to me that increased flow through the filter wouldn't mean much if it drew from a lower ambient pressure.Bob_Fout said:Yup, folks seek out the larger Euro OEM airbox parts when they bump the mods. Why can't a non-OEM solution be effective to?
For most this isn't as much of an issue as it is for me, but I just can't really run a stock airbox. There isn't enough room, so I run an akimoto cone filter that integrates a large velocity stack. I don't really think the stock setup even has sufficient frontal area for the inlet to produce any measureable ram air effect so the arguement largely comes down to temperature. Keep in mind that the air under the hood will all be replaced with fresh air before you ever hit second gear so I really don't see that as being a concern. It seems like people here make a lot of excuses to avoid spending money or doing anything that doesn't simply use stock parts off of another car. I figure it's a hobby and hobbies cost money. I buy things because I want them and I'm okay with that....shizzler said:It totally can. I'm glad you guys are keeping this thread alive with updates and info. The one thing I don't quite understand though is how you guys are happy to completely ditch the "cold" and perhaps slightly pressurized draw of the factory setup. While it might not be too significant, you are now simply sucking heated (perhaps) underhood air that could run at a significantly lower pressure when driving at speed. It would seem to me that increased flow through the filter wouldn't mean much if it drew from a lower ambient pressure.
For that reason I went this route:
http://forums.tdiclub.com/showthread.php?t=245261
probaly the filter was so restrictive the air was expanding due the vacuum created, this can achieve a drop in temp below ambientnicklockard said:Hmmm, so that must be how a "CAI" works, by defying physics!
Phew, at least there's one other sane person in this threadRub87 said:probaly the filter was so restrictive the air was expanding due the vacuum created, this can achieve a drop in temp below ambient
lol
I've got a better idea, I'm going to run a duct from my A/C vent up to my intake!nicklockard said:You guys would get better results by mounting a dorm fridge in front of the car with the door removed: then you'd have your ram air and your cold air.
Don't forget to put a smaller pulley on the compressor mike!vwmikel said:I've got a better idea, I'm going to run a duct from my A/C vent up to my intake!
oooh, overdrive....I might have to overnight parts from Japan....Rub87 said:Don't forget to put a smaller pulley on the compressor mike!
hahahaha thats great. That must chill the intake air to like 30 below ambient or sovwmikel said:I was thinking of adding an interfooler like this:
What do you guys think?
No, we've measured temps below ambient with just a cone filter. My suspicion is that the sensor might've been off a few degrees and was reading ambient....regardless, if it's reading at or around ambient then I don't see the temperature advantage of the stock airbox. I agree that the stock system is fairly well designed, but it was also designed to be an intake muffler more than anything.shizzler said:hahahaha thats great. That must chill the intake air to like 30 below ambient or so
Wait, why were we talking about temperatures below ambient? Did someone say the AFE did that?
My initial observations indicate this is not a WAI. Once I have a greater variety of ambient temps and driving speeds I'll post more.nicklockard said:Yeah, and these C(W)AI's....
They also race at an average speed of over 100mph though. So depending on filter placement in the engine bay, they could be much cooler than the average TDI bay around town....?Racer007 said:If you look at the production class race cars at the Grand-Am or ALMS races you will see they almost all run conical air filters. I am sure these race teams have tested and checked out pros and cons of these air intakes much more then we can and their underhood temps have to be much greater than our small TDI engines put out. Must be something positive to what they are running.
Hey, just to re-iterate, I think what you guys are doing with this filter is great, since you're right, its not the typical follow the crowd, sheep style modding. Just playing devils advocate. My girlfriend hates that about me.vwmikel said:No, we've measured temps below ambient with just a cone filter. My suspicion is that the sensor might've been off a few degrees and was reading ambient....regardless, if it's reading at or around ambient then I don't see the temperature advantage of the stock airbox. I agree that the stock system is fairly well designed, but it was also designed to be an intake muffler more than anything.
shizzler said:They also race at an average speed of over 100mph though. So depending on filter placement in the engine bay, they could be much cooler than the average TDI bay around town....?
I gotta disagree. Your comment inspired me to run some simple volumetric calculations. If you can engage the clutch with anything near full load at 2000rpm, you're going to empty a full 3" intake and airbox in under half a second. If you launch at 3000rpm with a stock intake its empty in more like 0.2 seconds. (I generously estimated 8 feet of 3" piping and a 9x9x12 inch airbox), with a volumetric efficiency of 1.8 (assuming a healthy dose of boost). Of course there is probably some lag that would add to these numbers. It's not about vehicle movement to push air into the intake system, the engine sucks it all through.milehighassassin said:Around town everything (both the OEM and CAI) is going to be pulling in hot air. There simply is not enough movement to get cold air in. You can have a filter on a tube sitting on the ground and the pavement is going to be giving off heat. Sure in the winter it might be cold, but what else might you be ingesting? The stock box isn't going to be pulling in any cooler air. All of these designs are based off of the car moving. Even moving at 50 MPH would be enough to keep a fresh supply of cool air.
Remember the stock airbox has a spring loaded hatch for higher revs to pull in air, where does that come from? (engine bay).
Thats a nice cooler I wish mine was that big. Why the hell would you waste the money to hook one up like that. lolvwmikel said:I was thinking of adding an interfooler like this:
I don't know, why would you waste your money on a Dodge Neon?KROUT said:Thats a nice cooler I wish mine was that big. Why the hell would you waste the money to hook one up like that. lol
