FS 2002 Jetta GLS
panda
Chichester, NH
2002 Jetta, 2015 Golf Sportwagen, 2005 Jeep Liberty CRD
FS 2002 Jetta GLS - $3000
I am the original owner of this car purchased for highway commuting. The car has served me extremely well since 2002 and the last 370,000 miles. I hate to see it go but it should be out there soaking up the miles. I have ALL the records of everything I've every done and almost every drop of fuel and oil put into the car. This is a great car with all the little things that go wrong addressed as needed over the years. It has the complete Kerma Borg S7 turbo and feed line kit for clean install with calibrated Bosio DLC 520 injectors. The turbo was replaced before the original failed. $3000 with tools and manuals. It is a sweet car with many extras including 2 sets of mounted tires with good tread.
You can view some images of the car here: http://roundsimaging.com/galleries/rounds-family/2002-vw-jetta/
  • 2002 MkIV Jetta GLS TDI
  • ALH engine code
  • Upgrades
  • Injectors Bosio DLC 520
    • Calibrated by Kerma.
  • Turbo Borg S7
  • VW Monster mats
  • CAT fuel filter
  • VW skid plate
  • Zero Start coolant heater
  • Extra set of wheels and tires
    • Summer Yokahama Avid Ascend 91H
    • Winter General Altimax Artic
  • Glass headlight covers
  • Magnetic oil drain plug
  • ProVent - uninstalled
  • Parts Replaced
    • Stock clutch and Flywheel
    • Front fenders VW recall
    • New battery 12/2017
    • Rear main bearing seal
    • Starter
    • Half shafts
    • Recent exhaust system
    • Driver side wheel bearing, stub, backing plate, wheel sensor
    • Radiator fan set
    • Turn signal stalk
    • Window lift bracket
    • Brake switch recall
    • Glow plugs and harness (multiple times)
  • Tools and Records
    • Metalnerd Tools
    • Timing belt tools
    • Injector puller
    • Rear brake retractor
    • Clutch alignment tool
  • Complete maintenance and fuel up records
    • From purchase 12/31/01
    • Sales brochure
    • Sale documents
    • Bentley Manual
    • VW CD
  • Engine hanger for TB change
  • Condition
    • Trim level GLS
    • 5 speed manual
    • Mileage 370,000
      • >90% highway commuting
    • No CEL or other warning lights
    • Runs strong
    • No smoke
    • Starts easily
    • No fluid leaks
    • No engine noises
    • Uses about 1 qt of oil every 4,000 miles unchanged since new.
  • Timing belt rollers, water pump and torque to yield bolts @ 280,000
    • Due in 10,000 miles
  • Interior
    • Black cloth - no tears or stains
    • Front and rear VW mats
    • Headliner intact
    • Heated seats functional
    • Heated mirrors functional, passenger side cloudy
    • Arm rest hinge broken
  • Exterior
    • Paint Galaxy Blue
    • Hood/Roof faded with some clear coat peeling
    • some chipped areas with surface rust
    • Front Fenders - new and painted when replaced under VW warranty
    • Rear Fender - small 2" dent right rear corner. Scrape/surface rust right rear wheel well
    • Mud flaps intact
    • No rust perforations
    • Rocker panel sound
    • Windshield - 2 stone pits
panda
Chichester, NH
Price without tools, $3900. This is a 1 owner car with complete records from the first tank of fuel, even includes the original sales brochure.
panda
Chichester, NH
Price reduced to $3500 without tools and I'll throw in a used (but never installed ProVent that I bought for a Jeep CRD that I once owned. This car has a recent turbo and rebuilt injector upgrade worth close to $2000 alone. This is a 1 owner car that has been very well maintained with many parts replaced. It has many extras including 2 sets of wheels and tires. I have all the records.
panda
Chichester, NH
Original injection pump? Pics of injection pump?
Yes, the injection pump is original. Don't know if you believe in these things but it's had the CAT filter for a long long time and Stanadyne or Power Service added at every fill up. I'll pull the cover and take a bunch of naked engine photos and add them to the Gallery. If spring ever comes I'm going to wash it and vacuum before I list it on Craig's list. I must admit I'm a reluctant seller. I posted here first because the folks on this site appreciate a well maintained car and may have an interest in the tools I've accumulated over the years.
By the way most all my posts since 2002 related to the care of this car, so if one is interested you can follow it's care. It has never been back to the dealer for anything other than the brake light switch recall (which they screwed up several times)
There are no leaks from the pump.
panda
Chichester, NH
This car is still resting in my garage waiting for a new home. Had considered keeping it but it needs to be out on the highway soaking up the miles. Price reduced to $2900.
