- Joined
- Jul 2, 2000
- Location
- Springfield, VA
- TDI
- ‘18 Tesla Model 3D+, ‘14 Cadillac ELR, ‘13 Fiat 500e
According to his previous post, his P3 gauge is monitoring cat temps instead of pre-turbo. If you're seeing 1300F, yours is monitoring the pre-turbo gauge. It would be nice if P3 would give you the option to select which sensor you want to monitor on your gauge.This seems odd to me. I have one in my '12 Golf and I will see over 1200 degrees in the first couple of miles as part of the warm-up cycle, and 1300+ in regen, 950 at idle during regen. I suppose it's possible that you didn't enter regen in 30 miles, but I would have thought you'd see the warm-up cycle. It's brief, so maybe you were looking at another measure. Also, at cruise (for me higher than 65) it's not uncommon to see 850-950 degrees.
We've got the Passat gauges showing up early next week: I'm going to ask P3Cars if they use the same sensor on that car as in the CBEA/CJAA. Don't see why they wouldn't.
If you're monitoring cat temps, then the warmup cycle is very muted (it will slowly climb to ~800F or a bit less rather than rapidly climbing to ~1300F seen by the pre-turbo sensor).
