Old April 4th, 2016, 19:30   #1
Humpty
Default Is the bew a good engine?
hey guys im wondering how the bew is compared to the alh. I've heard about the bew having cam problems is this true? And how common is it? In my search of a tdi I've learned that finding a clean alh 5mt takes a lot of patience. I've started looking into the bew and I'm wondering how reliable it is past basic maintenance. I've heard it gets slightly less mpg but also has a little more " spirit" if you know what I mean, lol. Also, how is the bew compared to te alh in terms of mods? Thank you
Humpty is offline   Reply With Quote
Old April 4th, 2016, 22:17   #2
buyingconstant7
buyingconstant7's Avatar
Fuel Economy: 5.7l/100km(winter) 5.0l/100km(summer)
The BEW is an alright engine, the first of the PD engine type(higher injection pressures with more precise timing allowing for better power and lower emissions compared to the ALH). It had cam issues, as does the BRM(found in the 2005.5-2007 Jetta TDI). It's not a "common" problem, it's an inevitable problem. The BRM certainly had it worse off for cam issues than the BEW. So you will run into cam issues with either engine, but if the car had correct oil it's whole life, it will take hundreds of thousands of miles to wear out, but most don't use VW spec oil, so it accelerates wear.
ALH is a clear winner in terms of fuel economy, mod-ability, reliability, and longevity. For power, the ALH was rated for 90hp/155 ft/lbs of torque. BEW at 100hp/177ft/lbs of torque. It's not a huge difference, albeit, slightly noticeable. Another thing to consider, is that the BEW can have injector problems. VW quoted my neighbour $1,000 CAD per injector for his BEW! He found a junker TDI and replaced all 4 for $200. They only had 80k miles on them and 30k down the road with these "new" injectors, they've gone bad again. I've heard similar stories.
To say the ALH is bulletproof, is an understatement. If you know diesel trucks, it's like the 7.3 of powerstrokes. Undoubtedly the most popular and the best diesel put into their cars. The ones that followed certainly declined in reliability and economy.
I'd say, find an ALH and mod it. They are an amazing engine, and they are generally known as the diesel engine that made diesels attractive again in passenger cars.
buyingconstant7 is offline   Reply With Quote
Old April 5th, 2016, 02:05   #3
Rembrant
Rembrant's Avatar
Fuel Economy: 50 MPG.
Finding a clean one in the rust belt is very difficult now.
Try finding a clean ALH 5spd without a sunroof and it takes even more patience.
Are you using that TDI for sale search engine?...Didn't somebody on here create that? I can't find it now...
Maybe somebody else can chime in here.
2006 White Jetta BRM TDI 5spd w/Black Leather.
2011 Black Lexus IS250 AWD. My wife's, the high roller.
1984 Ford F150 Stepside project. Old school 3 on the tree.
Rembrant is offline   Reply With Quote
Old April 5th, 2016, 04:26   #4
deeslman
Just my opinion,
Coming up on 9 yrs of ownership of a bew. Not one minute downtime in 200,000
miles. Beetle has been used hard. Find one that has had proper maintenance, and take a shot.
deeslman is offline   Reply With Quote
Old April 5th, 2016, 04:52   #5
jimbote
jimbote's Avatar
my personal golf has over 370k miles on the stock cam.... it smokes a little on cold startup because of worn guides and seals but runs great with a 1749vb and tune to match ...
Old April 5th, 2016, 04:57   #6
yatzee
yatzee's Avatar
TDI(s): see sig
I think the BEW is as good an engine as the ALH, and I say this having driven at least 100,000 in each one, if not more. Yes, they have cam issues, but none of the ones I've seen or wrenched on have shown any cam wear (as opposed to the BRMs)
I think there is a love for the ALH as being the best of the best - it's a great engine, but I think the BEW loses a few people because it's a bit different.
2015 Passat TDi 6 spd, 2005 C230 6 spd, 2002 3500 6BT NV5600, 1991 405 mi16, 1986 and 1987 190e 2.3-16 [SIZE=1]
yatzee is offline   Reply With Quote
Old April 5th, 2016, 11:14   #7
bmali98
Fuel Economy: 5.6-5.9
I like my BEW just fine. I have had some hiccups with it but what car doesn't. As far as PD engines go, from what I understand the BEW and the Passat equivalent (brm? dunno) are the most reliable of these engines.
bmali98 is offline   Reply With Quote
Old April 5th, 2016, 12:04   #8
RT1
RT1's Avatar
Fuel Economy: 43.3 mpg/10 Year Average - 80% HiWay
If your getting second hand (and what ALH, BEW or BRM isn't second hand at this point?) its all about the maintenance. I haven't had a single problem with the engine. Other than wear parts and a few predicted failures (trans solenoids, in-tank fuel pump) I have had no problems. The cam problem was over-hyped and seemed to relate more to the thinner profile of the BRM cam lobes and incorrect oil than to a overall design flaw or material failure.
BEW has a simpler protocol for T-belt change and a little more horsepower but it doesn't lend itself to modification like the ALH does. Changing the injectors in the BEW would be a huge PIA compared to the ALH. Knock on wood I have had no evidence of injector failure and haven't seen any threads on that issue that would cause alarm. I would say the BEW is a reliable workhorse and the ALH a fun engine to play around with so you have a choice.
'05 Golf PD - 396,000 miles
RT1 is offline   Reply With Quote
Old April 5th, 2016, 12:13   #9
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
BEW is a fine engine. From reading here over the years, they seem to be a miss-understood, harder for some to diagnose.
Old April 5th, 2016, 13:22   #10
bmali98
It should be noted that as far as injector changes go, the BEW is a lot more complicated however the stockers will get you to 160hp where the alh although easier to change will have to be changed to achieve this. To get to this power range is easier on a BEW. Less playing around for sure. Bolt on turbo, tune, go fast. Much more power than that and you need to further tear down either engine for head studs anyway so why not do injectors while its apart.
Old April 5th, 2016, 20:38   #11
WestVa304
TDIClub Contributor
My BEW had it's cam done at 220k currently at 300k now. However, I think the original owner took it to joe mechanic who put crap oil in it. Either way it's not a huge job especially if done in tandem with the timing belt.
Just check the cam every oil change or every other if it looks good. Records of using quality oil, and regular maintenance of course, would add a lot of confidence to the purchase.
Just an egr delete and tune makes it move really nice. Now a vnt-17 makes it great and the mpg's will compete with an ALH's.
I would buy another one in a hearbeat.
BEW- 333K, VNT17, EGR Del, Darkside SMIC, 16"wheels.
1z- 240K Ecodes, RC3, DLC520s, PD130 intake. (SOLD)
WestVa304 is offline   Reply With Quote
Old April 6th, 2016, 14:33   #12
UhOh
UhOh's Avatar
Everything is a trade-off. I think that some of the bias is due to the fact that there are more ALH engines out there?
I'd almost consider an BEW (I think the engines look cool!) if not for the fact that I'm already stocked with ALHs and I have tools for the ALH. Less complications with TB changes? No IP (to do funky things)?
Old April 8th, 2016, 21:19   #13
turbotorq
turbotorq's Avatar
TDI(s): 04 Jetta TDI
Fuel Economy: 45ish
I'm a BEW owner and I love mine. I drive the SNOT out of it too. I'm constantly revving mine hard, and towing a lot of weight. ( firewood, dump runs from House renos, picking up tools / shelving units etc from classifieds. I've put over 200k on my engine, the stock turbo SUCKS. Replace it with VNT 17 minimum and your golden.
Timing belt is more durable
Alternator is 100x easier to replace
Bottom end is bomb proof
Much more crisp sounding engine compared to ALH
More power stock
More tidy engine appearance
Much nicer cluster
Etc etc
To be honest the only benefits in a ALH are those wide lobs on camshaft and that stock VNT 15.
VNT17;PD150injectors;PD150intake;PD150oilcooler Tune;IMMOdelete;EGRdelete;ASVdelete w/RacePipe;KoniYellows;Frostheater;Erectonomy;DRL Disabled;HID's;VAGCOM
turbotorq is offline   Reply With Quote
Old April 8th, 2016, 21:36   #14
Mike_04GolfTDI
Mike_04GolfTDI's Avatar
The BEW engine is the best thing ever invented.
2004 Golf GLS TDI 5-spd, DC Stage 1 Clutch, Evolution Atlas Skid Plate, Malone Stage 4 Tune, GT1749VB Turbo, 3 bar MAP
Mike_04GolfTDI is offline   Reply With Quote
Old April 8th, 2016, 22:09   #15
nickfancher1
I'd avoid it like the plague, unless the previous owner has proper documentation that it has already been done. I had a 2004 VW Beetle (BEW) that I sold in December. My aunt was the original owner, and I had every service record from the dealership on time by the book. I took the valve cover off at 175k miles to inspect, it was very very worn. Time for a new one.
To me, that's unacceptable for an engine to need a cam at such low mileage. Or ever, unless it has like 800,000 miles. That's completely ridiculous and unless VW high-pathetically speaking were to pick up the tab, is downright terrible. $1500+ to have replaced.
I doubt my current Camry has cost $1500 over the last 209k miles in total for maintenance over the last 16 years. The Beetle I had, was around $9,000-$10,000.
Good luck. Look for an ALH.
(I better put my shields up for the flames I'm about to receive)
nickfancher1 is offline   Reply With Quote
WTB: Bad (or good) used turbo with good actuator valve for 05 Golf BEW engine sleepystevenson Private TDI Items for Sale/Wanted 3 February 9th, 2016 01:56
Wtb: Tandem pump for 04-05 BEW engine in good or bad condition MrRizzmeister Private TDI Items for Sale/Wanted 2 October 2nd, 2013 18:23
WTB GOOD Running BEW Engine NY,CT AREA. BlackCloud Private TDI Items for Sale/Wanted 4 September 6th, 2013 09:03
Looking for GOOD ALH engine/GOOD engine parts in south Mississippi for a rebuild. ericgray1 Private TDI Items for Sale/Wanted 2 July 24th, 2012 13:41
wtb: good bew engine midwest kleinergti1 Private TDI Items for Sale/Wanted 0 December 28th, 2010 13:50
Page generated in 0.19870 seconds with 11 queries
[Output: 129.68 Kb. compressed to 108.41 Kb. by saving 21.28 Kb. (16.41%)]
