this might be useful, might not:
Cat filter 1R-0749/P551311 uses 1"-14 threads
Also 1R-0755, still 2 micron absolute filter, but 46% larger OD, and 29% taller and has 1⅜"-16 threads.
Volume of 1R-0749 is 100 cubic inches, or 0.43 gallons, 1R-0755 is 273 cubic inches, or 1.18 gallons.
0749 is available and cheap ($9-19) and are in three lengths, also a water-separator(but much less filter efficiency). Base can be cheap($18-$50).
Cat filters rated at 98% 2 micron, Donaldson 99% and are only ones considered absolute.
Fleetguard 94% 2 micron.
BF1212 is best for emulsified water removal 95%.
Below is info compiled from
http://beyondbiodiesel.org/forum/index.php?topic=48.0:
FILTER HEADS (1-14" Thread)
Cat -280-2698
Donaldson P174777, Fleetguard 3304173S, fleetguard base 142784S and the Baldwin OB1308.
Perma-Cool 88864 High Flow Filter Head (1/2 NPT Inlet / Outlet)
Perma-Cool 81074 Fuel Filter/Water Separator Kit (1/2 NPT Inlet / Outlet)
Perma-Cool 81794 High Performance Filter Head (3/4" NPT Inlet / Outlet)
Fleetgaurd 142784S (1/2 NPT Inlet / Outlet)
Donaldson P174768 (7/8-14UNF)
Baldwin FB1311 (7/8-14 UNF Inlet / Outlet)
Fleetguard 3930618-S ( 1/2-14 )
Fleetguard 212013S ( 7/8- 14 ) This is the Dual Mount!
NAPA 4770
Wix 24770
FILTER NUMBERS
Cat Primary Filter/Water Separator 175-2949 (threads 1-14 UNS-2B )
Fleetguard FS19683
Donaldson P551743
Baldwin BF1268
Wix 33005
Luber-Finer LFF8030
ACDelco TP1002
Longer 11-12":
Cat Secondary Filter 1R-0749 (2 Micron) (threads 1-14 UNS-2B )
Fleetguard FF5319
Donaldson P551311
Baldwin BF7587 (BF614, Standard Version, BF7633, Short Version)
Wix 33674
Luber-Finer LFF2749 (High efficiency version of LFF5823B)
ACDelco TP1322
Fram P8335
Purolator F75185
Hastings FF1056 (FF1007, Standard Version FF1079, Short Version))
Shorter:
Cat 1R-0750 (2 micron) (threads 1-14 UNS-2B )
Fleetguard FF5320
Donaldson P551313
Baldwin BF7633 (BF7587, Long Version)
Wix 33528
Luber-Finer LFF3347
ACDelco TP1326
Fram P8334
Purolator F65213
Hastings FF1079 (FF1056, Long Version)
