Old May 15th, 2012, 19:49   #1
terrydtdi
terrydtdi's Avatar
Fuel Economy: BEST 58 ( 900 mile Club ) av. 46, worst 38, Mobil 1 TDT
Default The Dietzl Mod
I call this the Dietzl mod. The idea was inspired from a little project DanG144 was working on.
Here is a little more economical Cat 2 Fuel Filter housing, $36.00 from Napa, or Discount Fleet Supply for $19.00. Just trim the mount area off.
Edit : Filter Base Napa # 4770 , or Wix 24770
Here is the filter housing fitting and Napa part number. The fittings are made by Gates, and are $1.83 each including tax.
Here is the adapter fitting with the hose nipple
Here is Discount Fleet Supply's web site.
http://www.google.com/url?sa=t&rct=j...CQHRYEh-gJ8OvA
2K jetta gl tdi 5spd 401k, RC5+, 17/22, PP764's, ported head, ARP head studs, 11mm, 3" turbo back, Kerma OMI, PD150IT & race pipe, VR6 air box & MAF, Godspeed SMIC, 3 bar map, PD lift pump, 681 fift, TT LCA's, spindles, brakes, GLI rear brakes and interior, VR6 axles, mcnalley boost/egt gauge, SBC Stage 2 Endurance, bagged, Michelin Pilot Super Sports
terrydtdi is offline   Reply With Quote
Old May 16th, 2012, 07:57   #2
Abacus
That helpful B4 guy
Abacus's Avatar
Do you have a part number?
'97 B4: 453,000 miles Malone 3, PP520's, Stage 2 cam, SBC3, ARP studs, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR.
BUG*PWR 2013 Award Winner
Old May 16th, 2012, 09:00   #3
Baumeister
Fuel Economy: 57/46/42 on B20
Napa Part # 7440
http://www.fleetfilter.com/filter/wi...ses/24770.html
will fit the CAT 2 micron filter and a bunch of others. Here's the WIX 2 micron.
Wix 33528
Baumeister
'03 NB TDI, 5sp, Sundown Orange, Leatherseats.com 2-tone leather, Rear Fog, ventectomy, Valeo SMF clutch, DLC1019s, Bilstein TCs, Turbo "S" steering wheel, seat heater retrofit, ESP retrofit.
'94 Audi Cabriolet: 75k miles and awaiting its AFN swap...
Baumeister is offline   Reply With Quote
Old May 16th, 2012, 09:30   #4
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
Sweet. I'm all over this.
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old May 16th, 2012, 09:33   #5
loganbmx4gt
loganbmx4gt's Avatar
Is there a part number(s) for the ports also? Where does the return line go to?
loganbmx4gt is offline   Reply With Quote
Old May 16th, 2012, 09:39   #6
Lightflyer1
Lightflyer1's Avatar
The return is connected to the line back to the tank
Old May 16th, 2012, 10:42   #7
greengeeker
You'll need to adapt from 1/2"NPT down to a 5/16" hose barb to mate to the stock fuel lines. As stated the IP return line bypasses the filter and goes directly to the tank.
- Nick -
Old May 16th, 2012, 12:08   #8
Abacus
That helpful B4 guy
Abacus's Avatar
I assume no issues with flow?
Old May 16th, 2012, 13:04   #9
Lightflyer1
I too would like to know the part number for the filter head and the adapters for hose sizing.
Old May 16th, 2012, 13:22   #10
Ski in NC
Fuel Economy: 48-52 typical
Probably not a great mod for driving in very low temps. You are losing the thermo tee which heats fuel going to filter.
The fittings are harware store/hydraulic shop off-the-shelf items. Filter head p/n given a few posts up.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old May 16th, 2012, 13:40   #11
loganbmx4gt
Cheapest I have seen so far for the filter head is at the link Baumeister provided above. The fittings I have found at Lowes, Part # 79965 for 1/2" NPT to 5/16" barb, $2.37 each. And get a 5/16", 1/4" for A3/B4 guys, barb coupling for the return line which are right there in the same area as the first fitting.
Old May 16th, 2012, 14:28   #12
Honeydew
Nice job terrytdi. Good idea cutting off the mounting bracket.
Honeydew is offline   Reply With Quote
Old May 16th, 2012, 18:13   #13
McDillon86
McDillon86's Avatar
im new to the forums, so what exactly does this do?
McDillon86 is offline   Reply With Quote
Old May 16th, 2012, 19:24   #14
Lightflyer1
Lets you use a screw on filter that can be cheaper or can filter finer or can last longer, depending on what filter you choose to use. Not necessarily better, easier or more reliable.
Old May 16th, 2012, 19:28   #15
McDillon86
McDillon86's Avatar
ok so its like a oil filter relocation mod with better filter type?
The Evry Mod + Toggle Switch = Smoke Mod (Pics, Vids, & Links) PhunkFX VW MKIV-A4 TDIs (VE and PD) 19 June 9th, 2013 16:23
KEY FOB Window Mod (and wagon hatch Mod) ik0n Ontario 48 June 2nd, 2013 18:21
Has anyone used the MAP mod along with MAF & Evry mod? DJGonzo TDI Power Enhancements 9 April 19th, 2011 05:03
Unknown mod that really works... anyone know what this PD TDI mod is called? pietch TDI Power Enhancements 21 August 10th, 2008 12:44
another legroom mod for A-4 and other tripod seats (seat track redrill mod) unitacx Upgrades (non TDI Engine related) 0 November 17th, 2007 21:46
Page generated in 0.22367 seconds with 11 queries
[Output: 131.56 Kb. compressed to 109.64 Kb. by saving 21.92 Kb. (16.66%)]
