Scoutx
- Joined
- Jun 4, 2012
- Location
- Virginia
- TDI
- 2012 Jetta (6MT) - 1000 Mile Club (retired)___ 2015 Jetta SEL (6MT)
I will simply note that I tend to do a lot of my own maintenance, so with that in mind I bought a VAG cable several months after I got my car.
When I got the cable I scanned the car, and found a serious (class 2) fault. Which according to the mileage was present when the car went in for it's 30K service and apparently the dealer either didn't check it or couldn't find it. The data link was working in single wire mode, IOW, it had already lost it's redundancy. This with the car at 32K and warranty set to expire in about 4 weeks at the rate I was running up mileage. Took it to the dealer complete with the error printout and a week and a half later, after techs were flown in from Germany and jumper wires had been run all around the car ($$$ in labor) the fault was finally identified as the radio head unit. Replacement cost for that alone was $1,000 add in the labor costs, never mind airfare and so on for those factory techs.
So tell me, was $250 a good investment, even if I never used it for anything else?
Besides, I could pretty much sell it at any time for at least 75% of what I've got into it.
That said however, if you have a means to borrow or at least use a cable that's a better option for the occasional use.
I would also recommend you do a full scan and save the results (which includes the software settings (ie coding) of the various units. It may be information you never need, but if you do having it can make all the difference. Also I would recommend you document any changes in the coding that you make so you can restore things if you need or want to.
