Owned PV systems cost a WHOLE lot more.
You really need to provide some valid studies to back that up. You know the kind that say a kitchen remodel get you back 60% of your investment.
The studies need to control for the recovering housing market and a bunch of other things.
1. I can cover my home in an array for $18k.
2. Even better: check your MLS for SoCal, AZ, NV, NM, HI, anywhere sunny.
I don't need to source that. It's really danged obvious. My realtor ran comps when we bought our (1994 build date) house in 2014. He always excluded houses with owned PV because they're consistently $15k-$25k more. Go to Trulia or any home hunting website and compare similar houses of same class/size/feature set with and w/o owned PV arrays. The higher end the home, the bigger the premium (though admittedly they usually are better/more upscale installs of higher capacity.)
PV arrays hold their (relative) value--but the boost will obviously depreciate with quality of install, years in service, etcetera (panels wear out over a quarter century, and better ones come out). The systems installed in the last 5-7 years look a lot sleeker, low profile, and well integrated than systems of the 1980's and 1990's and even early 2000's. And, they're holding their value. Systems installed in the last 5 years have 20 years of service left w/o rebuild or retrofit.
2a. Were we to install said array, it would boost value of home by similar value. If we weren't saving for second home, It'd be a seriously evaluated option. (Disclaimer: we're massive cheapskates. our electric bill in Arizona summer peaks at $160/month, so the savings would be not as much for us than a typical family.)
