Tisey06
Good stuff, Impex sells LM diesel purge for $5.88 a can, can't beat that price.
nicklockard said:I'm not sure if it was noted in this thread (DD may have mentioned it), but several members have done used oil analysis tracking with every oil change and found lots of wear after performing this DP purge. I don't have time to search for the threads with those mentions, but IIRC, SunRG's UOA threads contain some of those posts.
It may be wise to change oil immediately after doing the DP purge, and only do this procedure infrequently. For some reason my car did not respond one iota to the cleaning.
Could it cause catastrophic damage, or something that appears that way?jollyGreenGiant said:Also, not too sure what repeated cleanings do to IP seals that may already be on the way out... Something tells me it's probably not the best thing for those seals.
DO NOT USE COPPER WITH ETHYLHEXYL NITRATE!debensey said:another way to use this stuff is to take two lengths of anealed copper tubing,
Well, I was letting air into the system. I put better clamps on the tubes and it worked fine. HOWEVER, the plastic tube did melt some inside the fuel return tube and it was a ****** to get out. I won't use plastic again - and if I can't use copper what should I do? cast iron???MikeS_18 said:Okay, I tried to do this today on my new wagon ('03) and had problems.It ran for about 3-5 minutes and then it stalled out and the diesel started to reverse flow - overflowing the DP can. big mess. What the heck am I doing wrong?
This should work, if it is empty enough, and you then run it almost empty again so that you give the DP a chance to work on the injectors long enough.ekkoh99 said:Can one run the fuel tank almost dry and then add two cans of diesel purge into te gas tank? Will that work?
I have a PD and I just did this procedure at 74k miles.blued said:Can someone please post a link to the PD version of this?
I didnt realise it was different and followed the guide on page 1. Immediately I found that a stream of diesel came out of the filter. I had to feed this into a jerry can at 5 litre intervals and keep dumping it back into the tank!
All the diesel purge eventually got use up. Have I wasted a can of purge and will have to do it again with a different method or have I gone the right way about it? Its not solved my vibration problem but the car felt a bit livelier!
