So I've had my TDI for about 2 months. Saturday morning I was on my way to work and it stumbled then died. Tried starting it again while waiting for my tow and got nothing but some smoke from the starter. After spending a day searching the forum I saw a few people wit the same issue and started trouble shooting. First thing i did was try to hand turn the crank which it moved about 90* each way before stopping. I pulled the glow plugs next and found one broken. I took a bore scope to the plug well and can see something obviously metallic. The PO said the shop he purchased the car from did the normal TB service, replaced the tension, the water pump and the valves. I took a peek at each one (mind you I'm on the clock) and can see that cylinder 1 and 4 ( I dont actually know if those are the correct numbers but going from left to right looking at the motor) are the only ones with any type of reflection material 1 being the cylinder with the broken glow plug. My non diesel knowing conclusion is the shiny bits on 4 is probably just a single valve that was replaced as well as maybe one valve on cyl 1 since 2 and 3 appeared to have nothing in it. Now do I just try to vacuum and blow out the cylinders and replace the glow plugs and harness (mine fell apart in my hands when I pulled it off) or do I need to dedicate two or three days to pull the head. (I've only pulled a head once on a car I was trying to make a project before I realized the body was riddled with rust.)
TL;DR
My car stopped while driving highway speeds and I found a broke glow plug clean it with a vacuum and send it or pull the head?
TL;DR
