PakProtector
My '04 BEW is going to get another turbo, and the GTD1752VRK looks quite good. As a sanity check, I am in need of a shopping list check.
intake: I will need a modified connection between the MAF and the compressor inlet. No solution yet.
Compressor to IC: the GTD has a nipple to run silicone tubing and a band clamp to the pancake( a 1.8T). This is no biggie...
IC inlet/outlet: the BEW has those funky clippie things. Installing an upgraded ALH IC ( tacotaco, etc ) will take me all the way to the IC outlet with band clamps...This is not so bad
IC outlet: With an upgraded ALH IC, going from the band clamp outlet to the clippie inlet of the BEW manifold needs a solution.
For the few ov you who have done this, pics and parts lists would be very much appreciated.
Thanks!
Douglas
Thanks!
Douglas
