shagin'wagen
Hi all,
As some know, I replaced my old clutch with a Stage 1 clutch with a 21 pound flywheel from TDIParts.com. The only thing is that the flywheel does NOT have a TDC mark on it anywhere that you use to set timing during a TB job. I was told that there is a tool out there somewhere that lets you find TDC without the mark.
Is this true? Anyone have experience with this? I want to confirm that my timing is 100%, as I am trying to chase down why the engine is using oil and I'm told that sometimes bad timing will do that.
