bendb
Hello; I am new to the forums, and TDI ownership. About 32 hours at this moment, actually.
I use to own a very loved 2001 Jeep Cherokee. I did everything on it short of engine and transmission rebuilds and body work. Unfortunately, I rolled it over (4 times!) at 60 mph in January.
A good friend was replacing his 2011 TDI sportswagen with a much newer BMW diesel. He let me borrow his car for four months while it was extra. Then it sat unregistered in my driveway for a month while we worked out a price we were both more or less happy with.
I purchased it yesterday, transferred the insurance and the plates, and went to go out and get some ice cream for my birthday.
Last night I turned the key, the engine cranked a tiny bit (a half second?) very slowly and then slowed to a stop. A few months ago, I had left it in the run position for 30 minutes and the battery was completely flat. So I figured after sitting for a month, the battery was dead.
I attached a charger, which seemed to indicate the battery was charged after just a few minutes of charging. I tried starting, and nothing. Then I put the charger in the 'start' position (50A) and still nothing. The car was not even trying to turn over. I left it charging overnight. Still dead this morning.
The battery looked to be the original for the car.
I was able to get a ride to my closest auto parts store, and bought a Diehard H6 AGM battery. (I did not have the luxury of choosing where to buy - I had only one store I could easily get a ride to and really needed the car to work today for an important errand.)
The old battery tested bad on their countertop tester - showing only 340 CCA. Plus it seemed likely to me a nine year old OEM battery needed replacement.
Got home, installed it - and nothing. Charged it with the charger, and it showed full after 10 minutes. No click of a starter solenoid.
It shows 12.7 Volts with a multimeter with the car off. With the key in the run or start position it drops to 12.4 Volts. I checked for voltage drop between the battery ground and what I think was the water pump - 0 Volts. I also checked from the battery positive terminal to the positive in the engine compartment fuse box - 0 Volts.
I read a lot of posts here, and the won't start page in the TDI 101 section. I can report that the headlights do NOT turn off when I move the key from run to start. The headlights seem very bright. Jiggling the key in the run position does not do anything. Everything in the car seems to work except for the engine. Which is a key bit of the car.
Lots of lights on the dash. I see a red battery the owner's manual calls the alternator light. There is an orange steering wheel, which I think only appeared after the battery change. Also indicators for the car skidding and a check engine light. The check engine light was on before all this started.
I do not have a VCDS set up yet. I have no manuals yet, although I have been told that I should buy the Bentley manual, and plan to.
What can I check next?
