Warranty Period The warranty period for the “Extended Emissions Warranty” limited warranty extension shall be the greater of: 11 years or 162,000 miles, whichever occurs first, from the vehicle’s original in-service date; OR 5 years or 60,000 miles, whichever occurs first, from the date and mileage of Phase 1 of the emissions modification. At the time of the subsequent Phase 2 modification, the extended warranty will be honored for 5 years or 60,000 miles, whichever occurs first, from the date and mileage of the completion of Phase 2. The vehicle’s original in-service date is defined as the date the vehicle was delivered to either the original purchaser or the original lessee; or if the vehicle was first placed in service as a “demonstrator” or “company” car, on the date such vehicle was first placed in service.
Parts Covered Under Extended Warranty The emissions system warranty shall cover the following parts or systems: The entire exhaust after treatment system, including the Diesel Oxidation Catalyst, the Diesel Particulate Filter, the Selective Catalytic Reduction converter, the dosing injector and other Diesel Exhaust Fluid system components, the exhaust flap, and all sensors and actuators The entire fuel system, including fuel pumps, high pressure fuel rail, fuel injectors, vibration damper, pressure control valve and all sensors and actuators The EGR system, including EGR valves, EGR cooler, EGR filter, EGR temperature sensor, all related hoses and pipes, and all sensors and actuators The turbocharger, including the turbocharger damper The On-Board Diagnostic (OBD) system, including SCR DEF quality sensor, and any malfunctions detected by the OBD systems other than those related to the transmission. Additionally, the engine long block warranty shall cover the engine sub-assembly that consists of the assembled block, crankshaft, cylinder head, camshaft, and valve train . The extended emissions warranty includes parts, labor, and applicable taxes. The extended emissions warranty shall not void or supersede any existing warranty. Conflicts concerning the warranty are to be resolved in favor of the consumer. More information about your extended emissions warranty coverage is available at
www.vwdiesellookup.com and in the customer letter we sent to you in January 2017
Extended Emissions Warranty Coverage (continued) Transferability This extended emissions warranty is fully transferable to subsequent owners. Warranty Notices All normal warranty provisions remain in effect…
