yesitburnsdiesel
The car is an 01 jetta with 235,000 miles. I've changed my timing belt 3 times and haven't had any issues. The belt on it now has about 40,000 miles and all of the timing points are still lined up. I was passing a semi at lower speeds in 3rd gear. Probably got the revs to about 4,000 rpm and as I shifted into 4th the engine quit. No smoke no noises just nothing. I have VCDS and there are no fault codes. The starter turns the engine over just fine and it will try to run for a second or 2 but thats all I get. Manifold and EGR are not plugged, I changed the fuel filter, still nothing. What next?
