8 Speed ZF transmission -how many litres for a fluid change?
A1sailor
Ontario, Canada
2015 Q5 TDI 3.0
Does anyone know how many litres needed for a fluid change in the 8 Speed ZF transmission?
I read a dry fill was about 9.5 l .
Alldata shows drain and fill at 3.6 - 4.0 liters. I'd say that is about right.
If you drop the pan and change the filter, it is closer to 5 liters.
We hook the cooler pipes to a machine and flush them, 14 liters, which is far better and less messy.
A1sailor
Ontario, Canada
2015 Q5 TDI 3.0
Thanks oilhammer, it will be a filter change along with the drain. For the filter, Meyle has a kit available with the gasket and pan bolts at a lower cost vs the OEM. Meyle is an OEM supplier and I have used them for filters in other German cars. Do you think the transmission filter needs to be original VAG or is Meyle ok to use?
mech644
Blue Hill, Maine
'00 Golf, '14 Touareg
For a transmission that has a retail price of 6k I’d get the VW filter and pan gasket. About $250 from idparts or fcpeuro.
In my experience Meyle parts have not been OEM quality, maybe the Q7/Touareg parts are better.
