LordGunner
Ive been searching the net for awhile now to see if I can find out anything on how to check if the Ignition Key Transponder is bad. The issue I am having is that my car worked fine and now the immobilizor is active.
So is there any way to check to see if it is the Ignition Key Transponder located around the ignition or am I just **** out of luck here?
