YukioMachine
I bought my JSW this past May with 30K miles on it. This is my first diesel vehicle. Since the temps have started to drop here in Minneapolis, I've noticed after it's sitting outside all day while I'm at work, it hesitates for 2-3 seconds after turning the key to start before turning over. I noticed the battery is the original so figured it must be related to that. I had the nearby Batteries Plus test the battery and much to our surprise, it tested out at 738 CCA! He looked up the specs for my car on the Batteries Plus computer and it says it requires 540 CCA. So, if that's the case, my battery should still be good and not the cause for the hesitant starting. Is hesitant starting normal for TDI's in colder temps (below 40F)? Being from Minnesota I feel funny saying below 40F for colder temps cuz that's not cold at all; it'll easily be below 20F for weeks at a time this winter. And I love it, I'm an avid cross country skier! 20-25F is the perfect temp if you ask me.
A friend of mine used to have a late 2000's Jetta TDI and remember something about turning the key then waiting 5-10 seconds for a light to come on on the dash panel before starting it.
Please let me know what you think. I plan to stop at my local VW dealer in the next week to have them test the battery and see what they think.
Also, for about the last week when I start my car, the dash message center says "X days til service." I checked the manual for more info on this, but no luck. What type of service is this referring to? I had the oil changed in June with 31,000 miles and was planning to go with a 10K OCI.
Thanks!
Thanks!
