Old January 29th, 2017, 14:46   #106
algirdas
algirdas's Avatar
TDI(s): 98 jetta AHU
Subscribed
98JettAHU, K03/4hybrid, RC3+, HifloX216, ColtStg2cam, PD130intake, Westach EGT&Boost, Mk4/O2Jshifter/selector, 5lug conv, TT12.3rotors, 11"rear disc, SBC-Stg2End, OBX-LSD,
algirdas is offline   Reply With Quote
Old June 24th, 2017, 19:23   #107
chaloux
Which hoses did you use to hook up the AC, and did you use the allroad or the passat condenser? My sister bought a swap and the person who swapped it used (as far as I can tell) the allroad condenser and left the passat hoses/compressor intact, but the one hose will not connect up to the condenser. Any insight would be appreciated!
Current: 04 Jetta Wagon TDI - DC stage I clutch/14lb fw - 01 Audi Allroad 6MT
- RIP 96 Audi A6 TDI Quattro - RocketChip tuned
- RIP 1996 Audi S6 mit ALH
- RIP 98 Beetle (LDL BGR)
EGR delete - Manual glow-plug button
chaloux is offline   Reply With Quote
Old June 24th, 2017, 20:15   #108
vwztips
vwztips's Avatar
When I did mine I used all the Passat parts to the firewall
vwztips is offline   Reply With Quote
Old June 26th, 2017, 18:09   #109
Owain@malonetuning
Glad to see more photos of this rig! Digging the shop chair, going to have to make me one of those. Would be lying if I said I didn't use GTI seats in my parts/N64 room, no wonder I'm single
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old July 17th, 2017, 08:28   #110
duwerk
Default AC Problem Solved??
Just wondering if you ever got the A/C working. My 02 S4 Avant with BHW is sorta the same thing. Something is missing in communications and fans and a/c will not function on their own. I can jump wires and force it to work but cant get the system to do it on its own. Among other issues, this is one I would like to try to fix. Let us know. Thank you
duwerk is offline   Reply With Quote
Old July 17th, 2017, 09:27   #111
vwztips
vwztips's Avatar
On my Allroad conversion the A/C head unit will turn on when it sees a tach signal from the engine. The normal BHW set up in the Passat gets that signal over the CAN Bus. Fortunately pin T94/28 is also a stand alone tach signal. I used this for the Allroad tach and just one of the A/C head unit controller wires. Once it see the that the engine is running it will turn on the compressor clutch.
Of course not 100% sure this will work on the A4.
Props to Hasenwerk for the pin 28 information!
Old July 18th, 2017, 06:25   #112
duwerk
Thanks for the tip about pin 28, maybe my cluster is not sending signal on one of the 8 wires that runs to and from the HVAC unit. But those wires are not really disclosed as to what they do. I do have tachometer working fine. I have tons of Can issues with different modules not wishing to speak with each other, but HVAC only reports it doesn't see coolant temp which is weird too as temp guage works fine on cluster and the ECU sees temp fine as well. All those wires that go from cluster to HVAC are pre existing, so I am not sure why A/C won't work or I have no coolant temp when I log in with VCDS. I should also be sure the HVAC sees RPM signal like you suggested. I have a lot of time into this over different periods. Then I walk away for a while and do other things and forget about it. I was really hoping to figure it out this time.
Old August 4th, 2017, 15:16   #113
GoremanX
GoremanX's Avatar
I've figured out that the ECU needs to be re-coded to support climatronic for A/C to work on my B5 A4 with BHW. With the OEM BHW tune, this is possible by just going to the ECU coding module in VCDS. However, if you're running a Malone tune, he uses a BEW file as the base for BHW manual transmission setups, and the BEW was never available with climatronic so you lose the ability to recode for that feature. When I flashed the OEM BHW file to my ECU and recoded for climatronic, A/C worked perfectly and the climatronic unit had complete control over it. But the engine runs like crap because it's a far cry from stock. As soon as the appropriate Malone tune is flashed, I lose all A/C functionality.
Last I heard, Malone is working on a fix for this issue, but it hasn't been done yet. In the meantime, I've hooked up a fused relay and switch that sends 12v directly to the compressor clutch so I can turn on A/C manually. This has served well enough, although I really hope it's just a temporary kludge.
GoremanX is offline   Reply With Quote
Old January 1st, 2018, 17:10   #114
Giantmcm
Subscribing as this will be my next project after I finish my current turbo build.
Giantmcm is offline   Reply With Quote
Old March 1st, 2018, 22:32   #115
Giantmcm
Hey Wingman, any update on getting the A/C up and working?
Also, where did you get your flywheel, clutch, pressure plate from?
2002 Audi Allroad ALH Conversion Dirty_Al TDI Conversions 45 June 2nd, 2018 08:07
02 Allroad BHW swap w/ euro TDI 6MT Scott02 Other TDI/Diesel Picture Gallery 23 August 21st, 2014 10:13
Looking into an BHW swap into an 2001 allroad arjax TDI Conversions 7 July 14th, 2014 21:06
Audi Allroad Diesel Conversion Dirty_Al TDI Conversions 14 October 14th, 2013 22:41
Audi 3.0 TDi Allroad donDavide TDI News/Tech 20 June 20th, 2007 08:34
Page generated in 0.10228 seconds with 12 queries
[Output: 98.33 Kb. compressed to 84.03 Kb. by saving 14.31 Kb. (14.55%)]
