Go Back   TDIClub Forums > VW TDI Discussion Areas > OBD Scanners
OBD Scanners Discussions on using On Board Diagnostic (OBD) scanners/ Diagnostic Equipment related to TDIs
Old November 15th, 2017, 13:40   #16
Lightflyer1
Lightflyer1's Avatar
I have my 1935 Ford for that possibility.
2015 Beetle TDI.
Old November 16th, 2017, 09:20   #17
740GLE
Originally Posted by Ol'Rattler View Post
If an EMP hits all your car will be good for is a green house or a shelter, and that is if you don't have KESSY.
Says the lemming that hasn't retrofitted their car's electronics with a Faraday Cage exceeding Mil Std 188-125-2.
Have fun fighting over the last twinky and can of baked beans!
hopefully my sarcasm was thick enough, I'm fully aware I'll be a goner in the first wave.
Old November 16th, 2017, 09:38   #18
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Originally Posted by badgator1 View Post
So Oily, relying on a cell service doesn't seem too bright. Do you rely on the Police and the Electric co. you sheltered little man?
Wow... Are you this much of a jerk all the time?
Proudly installing things where they're not supposed to go since 1996!
Windex is online now   Reply With Quote
Old November 16th, 2017, 11:33   #19
tadawson
Sadly, cellphone service is one of the lesser reliable services in the time of crisis. I cannot think of an incident (earthquake, 911, etc) in which cell service didn't immediately fold. In my early years, I designed some of the first cell systems in the US, and that kind of stuff was always in the designs at that time . . . but then carriers discovered that they could make more $$$ if they didn't bother to harden anything, and we have what we have now . . . a trendy, fragile, expensive system that generally becomes unavailable in times of need.
tadawson is offline   Reply With Quote
Old November 16th, 2017, 15:09   #20
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Well he is a Bad Gator. Criticizing oilhammer on here is like wearing a Down with the Pope t-shirt to a Catholic Mass.
Don't we want folks to share their thoughts?
Old November 28th, 2017, 16:42   #21
robm2
What does the VAG506M NOT do, compared to VCDS?
It looks like something like this is a good idea to have, but I can't stomach the cost of the Rosstech gear for my home use. Nearest dealer is 600 km away....
robm2 is offline   Reply With Quote
Old November 29th, 2017, 11:50   #22
BobnOH
not-a-mechanic
Originally Posted by robm2 View Post
What does the VAG506M NOT do, compared to VCDS?............................
Inquiring minds want to know
Old November 30th, 2017, 12:06   #23
jef@rosstech
Associate Ross-Tech Vendor
This device appears to be a generic knock off product of another knock off product, with China, no surprise that would happen.
It is easy to claim a product supports [XYZ]. However, no one at Ross-Tech has tested one of those, so we can't verify it does all that it claims. We know what VCDS can do and it has a +17 year proven track record to back it up.
http://wiki.ross-tech.com/wiki/index.php/Functions
http://www.ross-tech.com/vcds/tour/main_screen.php
What kind of support is built into the product? Long Coding Helper? Measuring Value Block labels? Login and coding charts? Readiness scripts? Full decrypt and description of +20,000 DTC numbers?
Use of the device itself? How easy is it to view MVB groups 001, 103 and 106 at the same time? Is it possible?
What about product support? Do they provide a phone number for free product support? Do they provide free software/firmware updates for the device? Do they maintain a free technical wiki site?
Jef blah blah blah
www.Ross-Tech.com
What should you do first with VCDS? AUTOSCAN!
jef@rosstech is online now   Reply With Quote
Old December 1st, 2017, 17:03   #24
robm2
No doubt the Ross-tech product is superior in every department you have mentioned. However, for $268 Canadian, plus another $300 for a laptop to run it on, I can't help but think of looking at less expensive alternatives.
If I can get 80% value for 10% of the cost, I will be very interested indeed. The question is, is it 80%, and what is left out in that 20%?
Old December 5th, 2017, 09:38   #25
BobnOH
not-a-mechanic
Inquiring minds want to know, seems folks don't like to say.
If you would need to buy a laptop, then your approach seems sound. One thing I've read about some aftermarkets is updates are not free.
Ross-Tech VCDS Vag Com / VCDS - HEX-USB+CAN Interface - Genuine Keven Private TDI Items for Sale/Wanted 4 July 15th, 2015 13:12
VCDS code: 16955, ENGINE WORKSHOP - brake switch replaced Hej456 OBD Scanners 1 January 15th, 2015 15:35
VCDS vs VCDS Lite jjbionic1 TDI 101 18 January 17th, 2014 16:08
MK5/MK6 VCDS lite vs VCDS Full?? storx TDI Power Enhancements 3 July 30th, 2012 11:15
Replaced MAF, VCDS still shows bad T-watts TDI 101 19 July 24th, 2009 10:50
Page generated in 0.18250 seconds with 12 queries
[Output: 100.22 Kb. compressed to 85.49 Kb. by saving 14.73 Kb. (14.70%)]
