Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
View Poll Results: Should this thread remain stickied?
yes 6 60.00%
No 4 40.00%
Voters: 10. You may not vote on this poll
Old March 3rd, 2017, 13:52   #631
Nevada_TDI
The Bently Biofuels station is still closed. I did some asking around and never got a specific answer. They are still providing their wholesale customers as far as I know. They might deliver to you if you have a big enough tank available for your "home heating oil."
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is online now   Reply With Quote
Old March 3rd, 2017, 15:06   #632
SFHGolfTDI
SFHGolfTDI's Avatar
Originally Posted by drsven View Post
Do you happen to know if Bently Biofuels is still in business? Last time I filled up at the Minden pumps was a few years back while visiting family in Carson Valley.
They were sold to Pacific Biodiesel a couple of years ago: http://www.recordcourier.com/news/bu...ntly-biofuels/
I think they still produce biodiesel there, but the retail operation, as you've seen, has been shut down.
Front end swap (Jolf), GTI tails, heated GTI leathers, GLI steering wheel, aluminum trim, center console w/cupholders, homelink visor, SGII, front/rear fogs, remote windows, 35% ceramic tint, Q5/Touareg rear wiper, roof rack, vented, PD engine cover mounts, Fumoto F106SW, panzer skid, Bilstein HDs, mudflaps, Conti PureContacts, custom 2" class II hitch. Kerma tuning. VCDS available (K-II USB).
SFHGolfTDI is offline   Reply With Quote
Old March 3rd, 2017, 15:45   #633
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
Thanks for the info folks.
2010 4D CWhite Golf TDI, 6 sp manual, Fluidampr, Bixenons, Rear Airbags, RNS-510, Dynaudio, DieselGeek SS & P2015 bracket, Force Fed Eng. Shifter Bushings. XB,UB, & RB UNIbraces; TyrolSport Brake Caliper Bushing, 2Micron Contain/PureFlow kits & timing belt cover, PolarFis MFD module, Euro light switch, R Red LED Tail Lights,Under Seat Drawers, Full color MFD cluster.
bobt2382 is offline   Reply With Quote
Old March 6th, 2017, 11:12   #634
rotarykid
rotarykid's Avatar
Fuel Economy: 64 .1city @ 30-60 mph/ 52-53 @ 70-85 mph hyway ( 52 to just under 60 normal around town)on LSD
Arrow
anybody else catch motorweek this week showing off, highlighting in the clean cities segment Plainfield VT.'s "Black Bear Biodiesel"?? the only public access in VT to B100....
It showed an at the pump sign for B100 @ $2.299........
More diesels than I can list
rotarykid is offline   Reply With Quote
Old March 23rd, 2017, 05:38   #635
BlueJay83
BlueJay83's Avatar
MikeS,
Just curious if you still have the GreaseCar kit?
I'm in Wilmington, DE.
Thanks,
Brad
BlueJay83 is offline   Reply With Quote
Old June 16th, 2017, 17:19   #636
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Interesting contact listing for Black Bear: malloybiodiesel at geemail dot com. Hmmmm, I wonder if this is an off-shoot of T H Malloy... So I look on Malloy's web site and I see their pump pricing no longer lists B50 nor B99. What?
I still have 20 gallons in the garage, and an indicated near-full tank in the car, so I'm good for a while, but I'll still call T H Malloy to check if they still carry my desired B99 (or higher).
If not, then either Newport Biodiesel, or Black Bear.
If the quantity of carbonic acid increases in geometric progression,
the augmentation of the temperature will increase nearly in arithmetic progression.
Svante Arrhenius 1896
Cogito ergo soy (I think, therefore: Biodiesel)
Lug_Nut is offline   Reply With Quote
Old August 1st, 2017, 16:48   #637
Lug_Nut
Lug_Nut's Avatar
THMalloy has updated their site and pump pricing. On-road, tax-paid, B99 is $2.089 gal. (1st Aug. 2017). That's just $0.01 more per gal. than their off-road, dyed, ULSD.
On the down side, Newport Biodiesel is no longer selling retail.
<edit> so I'm scrolling back to look for B99+ retailers in the mid-atlantic and I came to post #609 from 2015. THMalloy was retailing B99 at @2.799!?! <end edit>
Old September 2nd, 2017, 16:01   #638
Lug_Nut
Lug_Nut's Avatar
Black Bear is run by a Malloy family member, but is not part of T. H. Malloy.
Gas-Up in Asheville still has B99 bio, but the other retailer in Sylva NC has ceased carrying bio.
Old March 24th, 2018, 20:04   #639
luminousgypsy
I know that Propel's Diesel HPR does not contain biodiesel but it's made from renewable biomass (98%!!) and is available in California in a few locations. Also it meets all specifications so can be used in all diesel engines.
I feel like it should be added to the list.
https://dieselhpr.com/learn-more
luminousgypsy is offline   Reply With Quote
Old March 25th, 2018, 15:27   #640
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
Baltimore Biodiesel currently has B50 winter blend at $3.35/gallon.
-George Bernard Shaw
Premium Diesel Locations by State pyankura Fuels & Lubricants 25 March 26th, 2009 08:09
Diesel locations, prices in N.A Jetta_Pilot Ontario 3 July 13th, 2008 19:01
Locations for Methanol, NaOH or KOH, By State Schwrtz27 Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 11 June 4th, 2008 12:03
biodiesel locations sailor55 Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 1 August 21st, 2002 07:32
Are radar detectors legal in your State/Province? Sacha General VW Discussion 23 July 20th, 2001 13:14
Page generated in 0.16623 seconds with 13 queries
[Output: 104.31 Kb. compressed to 88.97 Kb. by saving 15.34 Kb. (14.71%)]
