TDIsyncro
Just thought I would fill you guys in on an alternative I have been reviewing. I have been looking at this because I plan to continue to push the HP limits with my BHW engine, and do not desire to have a BS module. I know this thread should almost be in the performance section, but thought it would be more appropriate here.
The reciprocating mass in the BHW engine is a fair bit more than that of other TDI's, whether ALH or BEW, or BRM. I do not have a lot of info on the ARL, but I think it is probably in the same weight range as BEW's.
This is a summary of parts I have recently weighed:
ALH Piston - 582g
ALH Rod - ?? no sample
ALH Pin - 206g
BEW Piston - 589g
BEW Rod - 631g
BEW Pin - 203g
BHW Piston - 620g
BHW Rod - 672g
BHW Pin - 203g - same as BEW
Piston weight includes rings, but not pin.
Rods weight include rod bolts.
For curiosity, I have found that the BKD, which is the 16V PD140 in Europe uses the same rod as the BHW, and uses balance shaft assembly. I suspect that it uses the same heavy piston design, but with a center bowl, rather than the offset bowl for the 8V PD's.
If we add up assembly weight:
BEW Rod/Piston Assembly - 1423g
BHW Rod/Piston Assembly - 1495g
The BHW assembly is 72g more than the BEW assembly. BEW is fairly smooth idling without BS, BHW is not.
SO these are the two changes I am considering:
No1 - Reciprocating Mass Weight Reduction
This can be accomplished by a replacing a number of items:
If I go with both the above options, I will be pretty comfortable running a 6000RPM rev limit.
No2 - BS Elimination:
EDIT - checked through all my ETKA sheets today double checking Main and Rod Bearing Sizes. BEW/BRM Mains are same as BHW, but use the smaller Rod bearings. BHW mains and rods are the same as PD130, PD150 (ARL), BKD..53.7mm. I have gone through my text and added (ARL where appropriate)
I beleive the ARL crank will fit the BHW block/Rods without any issues because I have found that the ARL & BHW share the same Rod Bearing shell's, main bearing shell's, and thrust bearing. I will add these part numbers to this thread when I get a chance.
BHW, PD130/PD150 Con Rod Bearings: 038-105-701-B & 038-105-701-A (53.7mm Journals)
BEW/BRM Con Rod Bearings: 045-105-701 & 045-105-701-A (50.6mm Journals)
BHW/PD130/PD150/BRM/BEW Main Bearings: 038-105-561-AM & 038-105-591-AM
One other issue I have been considering is increased oil pump capacity. I suspect that the BHW may have a higher GPM oil pump than the BEW(or ARL). It would be nice to get a hold of an old BHW oil pump from a disgarded BS assembly and compare the flow rate to the BEW pump(or ARL). This could be done with a simple bench top set-up to get some hard numbers. If this is true, the BHW has an advantage over the BEW (or ARL).
I will also be doing some minor changes to my pistons, one of these will be a small increase in the omega bowl size. I would like to retain the same geometry proportions in this procedure, but it will give me a slightly larger opening that will fit a bit longer duration of injection, and a slightly lower compression ratio for higher boost levels. I have a cross section of a BHW piston which I will post later this week for general interest. It shows the thickness of the material in the various areas, the design of the omega bowl, the oil cooling passage, etc.
And I would like to thank texascadillac42 for donating his parts to me for a bit ( and he would like to sell them if possable ) and I would also like to thank Oilhammer for shipping them out so promptly.
Feedback and comments welcome.
ALH Piston - 582g
ALH Pin - 206g
BEW Piston - 589g
BEW Rod - 631g
BEW Pin - 203g
BHW Piston - 620g
BHW Rod - 672g
- Rosten Rods - Stronger and lighter weighing in at 575g (97g savings), cost, approx- 650US
- Titanium Wrist Pins - Stronger and lighter weighing in at 130g (73g savings), cost - 450-600US/set depending on quantity
- Replace BS drive sproket on BHW crank with BEW Sprocket from donor crank and use BEW oil pump, or..*
- Replace BHW Crank with EDIT - PD130/150 crank (or BEW crank with correct Rosten rods) and use BEW oil pump*
