this is what I'm doing
http://pics.tdiclub.com/data/500/thumbs/MVC-022S.JPGhttp://pics.tdiclub.com/data/500/thumbs/MVC-019S.JPGhttp://pics.tdiclub.com/data/500/thumbs/MVC-020S.JPGhttp://pics.tdiclub.com/data/500/thumbs/MVC-021S.JPGhttp://pics.tdiclub.com/data/500/thumbs/MVC-022S.JPGhttp://pics.tdiclub.com/data/500/thumbs/MVC-018S1.JPG I want to change the vacuum lines to silicone I forgot what and how much I need does anybody remember thanks
5mm x 3mm
150 mm from air filter box to plastic pipe plastic pipe (N 020 282 1 shorten to 660mm) to 150mm of hose to N75 fresh air nipple elbow 333 955 665 out from N75 to connecting piece N 901 326 06 3.5mm x 2mm 420mm from connecting piece to turbo actuator 420mm from vacuum T at back of engine compartment to check valve 046 905 291 A 40mm from check valve to plastic pipe (N 020 139 1 shorten to 620mm) 40mm from pipe to Y piece 056 129 971 angled hose 034 133 784 L from Y to N75 inlet (top nipple) 140mm from Y piece to vacuum reservoir (damper) |
Awesome, keep us all posted with updates.
You could do something similar to what I did with my Vacuum lines: http://forums.tdiclub.com/showpost.p...&postcount=160 I routed them all behind the first firewall by the cabin air filter. Jon |
