reflextdi
I have a 2003 with 57k miles and haven't had to change the MAF on it yet. I got a CEL yesterday and it has the symptoms of needing a MAF replacement. I'm contacting a local guy on the list with VAG-COM just to be sure but I have a couple of questions:
1. Do I need to re-set any errors or faults in VAG-COM after I fix it, or do they automatically go away when the problem is fixed?
2. World Impex lists a TDI ALH and also a TDI BEW on the home page when you sort by make and model. Any idea what the difference is? Mine's a late-year 2003 Jetta sedan, GL trim.
3. Impex has three different MAF's for my car. One is the OEM VW, one is the Bosch and one is a Pierburg insert. Sounds like the Bosch and VW are the same part in different boxes (and different prices...). I thought (from reading FAQ ) that Pierburg and Bosch were not interchangeable but both are listed for A4 TDI's. Any recommendation on which one I should get - again, assuming that this is the problem?
