TDIClub Forums
TDIClub Forums (http://forums.tdiclub.com/index.php)
-   Private TDI Items for Sale/Wanted (http://forums.tdiclub.com/forumdisplay.php?f=16)
-   -   TDI complete drivetrain/subframe setup (http://forums.tdiclub.com/showthread.php?t=354887)
Busguy71 June 9th, 2012 07:01
Sold
I was saving all these parts to build a custom tdi powered old-beetle, but I decided to sell instead.
I have a '98 TDI AHU engine with 5 speed trans from a jetta, with complete sub-frame, shifter and linkage, radiator, wiring harness with computer, steering column with ignition and key, all the intake piping to and from turbo including the air box with MAF, the intercooler, all associated coolant hoses and reservoir, vacuum hoses with all the stupid switches and relays, steering rack, control arms, knuckle assemblies, and hydraulic clutch setup, gas pedal, probably more I'm forgetting too. 298k on motor, trans shifted well. $1200. Email if you're interested. Busguy71@aol.com will not ship
CJansen June 11th, 2012 16:22
if you wanna part some of that out let me know!
Busguy71 July 7th, 2012 15:01
Price reduction!
Busguy71 August 15th, 2012 10:34
$1200!!!!!!!!!
cruisertime August 16th, 2012 21:29
Yeah if you part it out, I would like the gas pedal assembly w/sensor and its connector.
coalminer16 August 17th, 2012 10:54
If you were only closer-would fit in my rabbit nicely with all the needed parts.
Page generated in 0.07349 seconds with 8 queries
[Output: 5.74 Kb. compressed to 5.47 Kb. by saving 0.27 Kb. (4.66%)]
