E_S
PD TDI missing/stumbling - measuring block #13, one cylinder too high
PD TDI (1.9TDI 130 hp) having some slight "missing" under load. Measuring block #13 shows the following values at idle:
#1: -1.60
#2: -2,05
#3: 2.99
#4: 2.05
Cylinder #3 is on the max of the adjustment range, and they are pretty much all kinda "out", although the limit is +/- 2.8.
The injectors #1 and #3 were replaced with used items a few months ago by a shop. Is there a possibility that the shop can have messed up the lash adjustment, and doing a new adjustment might fix the problem?
#1: -1.60
#2: -2,05
#3: 2.99
#4: 2.05
