I bought this car about a year ago, then the injection pump went out. The mechanic screwed up the timing and smashed some valves. not sure if the pistons are good but been told by others on here that there's a chance they are okay.
It has a brand new 11 MM injection pump bought from Idparts.com, as well as brand new sprint 520 injectors that I got with the hotswap option from kermatdi so the bodies are new also. They were mounted and calibrated by kermatdi, also has a kermatdi 100k timing belt kit. I have receipts for all the parts and they all have less than 100 miles on them.
The interior and body are in rough shape as the car has 270,000 ish miles on it. The engine and transmission has roughly 200,000 as the previous owner swapped it from a auto to a manual and put the other engine in also.
I was debating on keeping it but with the Holidays I could really just use some cash.
I am asking $1,500.00 but make me an offer you feel comfortable with. That's about the value of the new parts that's on it minus the timing belt cause I'm not sure if the mechanic messed it up.
I have pictures and receipts as well as a clean and clear title on hand. call or text Jake at 7175529821
