ReallyBigAir
Hello All,
First post here on the TDIclub forum.
We recently purchased a 2013 Passat TDI SEL Premium w/68K miles from a local VW Dealer. Clean carefax, all relevant maintenance performed before the buyback. Emissions fix was perform 10/2019 by said dealer and brake rotors/pads, tires, battery, fuel filter were replaced and oil change performed.
I did consult the forum before buying the Passat. BTW, have a family member who owns 3 VW TDIs and they love them. Also have another family member who has owned VW and Audi diesels.
We've driven the car about 3500 miles since purchase and I've noted a significant amount of oil consumption. It is using about one quart of oil per 1200/1300 miles, best I can tell. May be a bit more, or a bit less. I see no sign of any oil leaks and there is no black soot in the tailpipe. No smoke either. However, I do think the car has an unusual mild smell in the cabin, like heat burning off paint or possibly a very mild burning oil smell.
Couple of questions: Is this amount of oil consumption "normal" and expected? If not, what should I look for as a cause? Any obvious typical leak spots that do not show oil drops on the ground underneath the car? Anything to look at as potential signs of oil burning, even with no visible sign of smoke or soot?
I like the car, love the fuel economy and the torque kick in the pants at part throttle. Lots of great high-end features for the cost of admittance for a dieselgate car. However, it will be driven mostly by my wife and son and they are not the most diligent about checking the oil regularly. Would hate to run it low on oil and cause an issue.
Thanks for any advice or guidance you can provide.
